Old 26th Sep 2019, 2:29 am   #1
qrpeter
Default Heathkit HW16
Hi
Have just acquired the above transmitter/receiver, and it seems to work fine, have had a couple of QSO's with it. Problem is, it only gives about 40w power, when the spec for this rig says the input should be 40 - 90w. What could be the problem, maybe replace the final valve? Any suggestions appreciated.
Thanks
Peter G0JJI
qrpeter is offline
Old 26th Sep 2019, 11:27 am   #2
Keith
Keith's Avatar
Default Re: Heathkit HW16
Peter,
I think you'll find that this rig is from the days when power was defined as DC input to the PA valve. If the PA is a 6GE5 it has an anode dissipation of 17W so 40W out is about right.
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 27th Sep 2019, 1:35 am   #3
qrpeter
Keith
Yes, you're right, had a chat with the "Elmers" at the club this evening, 40w out for an input of 90 is right. Thanks for the reply. Don't know if you have had any experience with this rig, but the audio seems a bit quiet, need 'phones for it. Maybe an addition of an AF amp would be good.
Peter
qrpeter is offline
Old 22nd Nov 2019, 6:32 am   #4
IsquaredR
Peter, I just saw your thread and want to add that you will also likely see the RF output drop dramatically as you increase frequency. On 80 meters that 40 watt RF output may to perhaps 10 watts up on 15 meters. These were compromise rigs built largely by neginners with no experience so it might also benefit you to go through it and do a careful alignment. Nonetheless it is a fun transmitter and receiver molded into one box. Enjoy!
IsquaredR is offline
