Old 15th Mar 2020, 4:29 pm   #1
ChasHeater
ChasHeater's Avatar
Default Yaesu MD-100A8X Adaption
Hello Gents, I know this is not strictly a vintage radio question but hopefully I won't offend. I have had for some time a Yaesu MD-100A8X dynamic microphone. I was hoping to use it on my FT-8900R VHF/UHF radio. This question is this: can it be done?, and done with some control over the up/down frequency. The mike has an RJ-45 8 pin connector and the standard 8900 fist mike a RY-45 6 pin. Anyone tried this and is there either a pre-made cable or a wiring diagram to make one. Ive search the net without much luck. Thanks in advance, Charlie.
ChasHeater is offline
Old 15th Mar 2020, 5:42 pm   #2
g4aaw pete
g4aaw pete's Avatar
Default Re: Yaesu MD-100A8X Adaption
Hello Charlie
it's a question worth putting to nevadaradio.co.uk
If an adapter is available, they're a likely supplier.
Regards
Pete
g4aaw pete is offline
Old 15th Mar 2020, 10:07 pm   #3
Dave757
Hi Charlie,
Could you not buy a MH48A6J mike which are advertised at less than
a tenner on the Internet, remove the lead from the mike , and
rewire this into an 8 pin round plug to fit the MD100A8X.
Kind regards
Dave
Dave757 is offline
Old 16th Mar 2020, 9:28 pm   #4
ChasHeater
ChasHeater's Avatar
Thank you for your replies, I have done a bit more digging and found some info, but there may be an impedance mis-match too.
