9th Aug 2008, 9:11 pm | #1 |
my first real restoration
Hi everyone,
have been tinkering about for a bit but I got a dac90a and thought about time I did a proper job. The cabinet was very dull but did not have any scratches, when I took the back off it had about 50 years of dust and a couple of dead spiders and plenty of cobwebs. I fired it up with my lamp limiter the dial lamps glowed as did the valves. rather bravely I pluged it direct to the mains and it started playing music with lots of mains hum then smoke started to emit from it so I quickly unplugged it. I stripped it down and found the mains capacitor had blown itself in half, not a good sign. Anyway I stripped the chassis down and cleaned it up it now looks like a new one. I replaced all the suspect caps and of course the ul41 valve . I used brasso for the cabinet and it shines like a new pin The deflector for the dial lamps was yellow and very dirty It cleaned up a bit but not as well as I had hoped. The speaker grill was a lovely shade of yellow/brown but some soapy water brought it back to golden. Anyway put it all back together and after initial tests plugged it in and to my amazement worked fine. I know the dac90a is an easy machine to work on but it has given me the confidence to tackle another. Hope I have not bored you Regards Paul |
9th Aug 2008, 9:22 pm | #2 |
Re: my first real restoration
Well done as always! How about a picture?
Are you sure the UL41 was faulty? Cheers, Steve P.
9th Aug 2008, 9:33 pm | #3 |
Hi Steve I will try and put some pictures on tomorrow
As for the valve I was told it was the most likely suspect for mains hum which this set had, so I replaced it anyway and now no mains hum,could it have been the bad caps giving it mains hum? Paul |
9th Aug 2008, 9:43 pm | #4 |
Sorry forgot to say the only thing anyone had done to it was to remove the mains plug in the chassis and poked the wires through with no restraint, so I wired it up directly to the on/off switch properly.
Thought about replacing the plug but then decided this was the safest way, not strictly original but much safer. Paul |
10th Aug 2008, 12:24 pm | #5 |
Very likely the UL41 needed replacing, but there's an issue with the DAC90A which as I recall kept at least one of my UL41s in service. Pins 3 and 4 of the valve base shouldn't connect to anything inside the valve, but with some examples they do: the 90A uses one or both of the valve socket tags as connection posts. Removing wires from these (whilst of course keeping their connectedness to one another ) is sometimes all it takes to cure mains hum.
Paul |
10th Aug 2008, 8:19 pm | #6 |
Hi Paul,
thats a good tip to try as the price of ul41s keeps going up, I have kept the old one from my set just in case Regards Paul |
