Old 6th Aug 2008, 3:52 pm   #1
Mark the Mender
Default My first One, Murphy U472
I have finally plucked up the courage and done it! (with helpful advice from Steve P, along with a couple of raps on the Knuckles and "no do as I say").
When the set came there was no back and V5 mssing (thanks Setsappeal).
There was much dust and several stowaways.......which were rehomed in the garden, however having been baffled lookng for grub screws on the dials for a couple of minutes i got them off without breaking anything.
The chassis was removed along with the speaker still attached. It was boxed and one visit to Steve later caps ordered. Steve gave it some power and there was life, which gave me hope.
In the iterim the cabinet a given a good dose of T Cut and elbow grease and the dial glass repaired. In the absence of a back I made one from fibre board I had in the shed.
Caps 49, 52, 58, 59 and 71 were replaced along with a new fuse,
the caps were put in one by one, after each time power wa applied to test functionallity, until the day cam to put it all back together, After a couple of hiccups, some resoldering, and an equivalent 10P18 being installed the set was soak tested, all was fine..........time for a
It was then I noticed the dial light was dead, new bulb and a check of the circuit......nothing accross the bulb so either S2b the on off switch which powers it is U/S or the resistor is, but the set i working so that is a job for another day,
The set is now by the PC for my enjoyment (and its small enough to fit)!
Name:	caps under chassis.jpg
ID:	18976   Click image for larger version
Name:	rest chassis.jpg
ID:	18977   Click image for larger version
Name:	old waxys.jpg
ID:	18978   Click image for larger version
Name:	U472 chassis top.jpg
ID:	18979   Click image for larger version
Name:	U472 front.jpg
Mark the Mender is offline
Old 6th Aug 2008, 4:29 pm   #2
Mike Phelan
Mike Phelan's Avatar
Default Re: My first One, Murphy U472
Well done, Mark - that's just the first one ...
BTW, your pictures are just thumbnail size when expanded.
Mike.
Mike Phelan is offline
Old 6th Aug 2008, 8:50 pm   #3
howard
howard's Avatar
Well done Mark,
That's a nice little set now. I hope there are a few more in the pipline ?
I restored my first valve set only a couple of years ago and now I've got 45 !
Howard
PS: Your pics are very small
howard is offline
Old 6th Aug 2008, 9:19 pm   #4
Mark the Mender
Having a bit of bother with the image sizing
cheers Mark
Name:	caps under chassis1.jpg
ID:	18985   Click image for larger version
ID:	18986   Click image for larger version
ID:	18987   Click image for larger version
Name:	chassis in cab.jpg
Old 6th Aug 2008, 9:21 pm   #5
Mark the Mender
Originally Posted by howard View Post
Well done Mark,
hopefully Howard, I have a Fenman 2 that needs some work, now I have a bit of confidence I hope to do some more, keeps me occupied
Old 6th Aug 2008, 9:39 pm   #6
mark pirate
mark pirate's Avatar
Well done Mark, i have restored one of these little murphys, a very nice little set & well worth restoring, i trust you now have 'the bug' & get stuck in to the next one
Mark
mark pirate is offline
Old 8th Aug 2008, 5:43 pm   #7
Steve_P
Steve_P's Avatar
Good set there, Mark. I like the back. I have a set here with a back made from a cereal packet. (Not by me!). If you are feeling amenable...
Has your daughter found it yet?
Cheers,
Steve P.
Steve_P is offline
Old 8th Aug 2008, 8:14 pm   #8
Mark the Mender
No steve it is out of her way
always amenable to you old bean
cheers Mark
