Old 19th Aug 2019, 7:20 am   #1
Nukeybrown
Default Valve identity
Pulled from a working set , just cant remember which one lol
Nukeybrown is offline
Old 19th Aug 2019, 7:44 am   #2
snowman_al
snowman_al's Avatar
Default Re: Valve identity
EL84 (or similar output type 6BQ5 etc.)
Alan
snowman_al is offline
Old 19th Aug 2019, 7:49 am   #3
Syrinx1
I've heard that if you freeze valves, it can temporarily reveal the valve markings on the glass envelope.
Never done this myself, but might be worth a try?
Syrinx1 is offline
Old 19th Aug 2019, 8:20 am   #4
snowman_al
snowman_al's Avatar
... should have asked how many pins on the base. 7 or 9?
If it is a Mullard (Philips family) valve there could still be a code round the bottom.
Old 19th Aug 2019, 9:05 am   #5
Restoration73
Restoration73's Avatar
If the other valves are "U" types, then UL84
Restoration73 is offline
Old 19th Aug 2019, 11:19 am   #6
terrykc
Yes, etched into the glass so, unlike the other markings, it can't rub off.
Two rows, one identifies the valve type, the second the date and place of manufacture.
Full details - including a translation of the type codes - here: https://frank.pocnet.net/other/Phili...CodeListAB.pdf
terrykc is offline
Old 19th Aug 2019, 2:05 pm   #7
Yes I'd say it's an EL/UL84-series. The anode isn't big enough for it to be a 5763.
Sometimes if you breathe on the envelope it can reveal the markings - could this (or rather the condensation that would form on the cold glass) be the same idea as the putting-it-in-a-fridge trick?
Ultraviolet light (from one of those hand-held forged-banknote-detectors) could be worth a try too - residual markings might glow!
Old 19th Aug 2019, 2:27 pm   #8
barrymagrec
I can only see 7 pins - EL90?
barrymagrec is offline
Old 19th Aug 2019, 8:46 pm   #9
Nukeybrown
Can't see any numbers, I have tried with uv lighting. It's a 9 pin. My guess was a UL84 but that was just a guess. Had it for a while so couldn't say which set of valves it came out of.
Old 19th Aug 2019, 8:54 pm   #10
If they are intact, a check of the heaters cold resistance should indicate whether it's a UL84 or not.
Old 19th Aug 2019, 9:20 pm   #11
Nukeybrown
71 ohm cold resistance pins 4 & 5
Old 19th Aug 2019, 10:17 pm   #12
McMurdo
McMurdo's Avatar
my EL84's more or less read short when cold, might be a P series?
Kevin
McMurdo is offline
Old 20th Aug 2019, 7:11 am   #13
snowman_al
snowman_al's Avatar
I've just measured a UL84 cold and have 69 ohms.
(Also a couple of UL41s at 70 to 71 ohms - they are 45 volt 0.1 amp heaters same as the UL84)
Checking an EL84 heater resistance, it is less than 1 ohm.
Alan
Old 25th Aug 2019, 1:33 pm   #14
Maarten
Unfortunately, Philips never etched those codes so they can and sometimes are rubbed off. They used a somewhat better ink since it had to survive the chalk print process and then a few years to have proof of warranty.
Maarten is offline
Old 26th Aug 2019, 4:15 pm   #15
terrykc
I have seen codes printed on bakelite bases and on the underside of B8A valves but all B7g and B9A valves I've ever seen have had the code etched in the glass and large numbers of valves sold in the UK under the Mullard trademark were manufactured in Dutch factories.
terrykc is offline
Old 26th Aug 2019, 5:47 pm   #16
m0cemdave
I think what Maarten is saying is that technically, they aren't etched. It's actually an "almost-indelible" ink.
I have seen a few valves where it has partly rubbed off, but that is unusual.
m0cemdave is offline
Old 26th Aug 2019, 7:22 pm   #17
HamishBoxer
HamishBoxer's Avatar
Put 6.3 volts across the heaters and all will be revealed,UL or EL.
HamishBoxer is offline
Old 27th Aug 2019, 12:11 am   #18
Nukeybrown
Sorry for the late reply its a UL84 just tried it in a set, works good sounds nice. Thank you
Old 27th Aug 2019, 2:48 am   #19
Maarten
Please examine more closely. Maybe try to rub it out with some spit or even alcohol on your finger. Etched numbers won't rub out but these will. I've seen it often enough (whenever I get a set in, I make note of all numbers).
Maarten is offline
Old 27th Aug 2019, 11:34 pm   #20
Nukeybrown
I will have anther look tomorrow for etched numbers but to be honest im thinking theres none there
