Old 3rd Aug 2008, 11:55 pm   #1
mark pirate
mark pirate's Avatar
Thumbs up 1947 Dac90
Hi all, have just finished the restoration of my dac90, which has been a real
pleasure to do After stripping it down i found apart from decades of muck,
that it was a very original, unmolested set with all original valves.
Unlike it's newer brother (dac90a) it uses larger octal valves & with it's dropper, it tends to run hot & burn a hole in it's back & this set was no exeption. After a good clean the chassis looked good but had the usual crumbling wiring to the dropper,after replacing this and a few capacitors,
i slowly powered it up via my variac & was rewarded with a dial light & the valves started to glow, a few more volts & away she went
Amazingly this set did no have the usualy crackley pots & switches (judging by the greasy film on the valves, this must of been used as a kitchen radio)
maybe this helps? Then to turn to the case which under it's layer of dirt & grease was undamaged but very flat in appearance, so i used my method of restoring a lovely shine by using t-cut followed by silicone wax.
After cleaning the speaker cloth & dial glass i reassembled the set.
The last job was to repair the charred back using sections of a scrap back &
araldite. (to make the set safe) I am listening to the set as i write this & it sounds great It can now take it's place in the house, to keep it's
younger brother & my tv22 (next on the list!) company.
ID:	18900   Click image for larger version
ID:	18901   Click image for larger version
ID:	18902   Click image for larger version
ID:	18903   Click image for larger version
mark pirate is offline
Old 4th Aug 2008, 12:20 am   #2
Tazman1966
Tazman1966's Avatar
Default Re: 1947 Dac90
That's lovely Mark. The more I see these sets, the more I like 'em and yours looks particularly shiny.
All the very best,
Tas
Tazman1966 is offline
Old 6th Aug 2008, 8:44 pm   #3
howard
howard's Avatar
Well done Mark
That's a great shine you managed to get on your DAC90 case, not many 60 year old bakelite cases look as good as that !
Howard
howard is offline
Old 6th Aug 2008, 9:35 pm   #4
mark pirate
Thanks for the comments taz & howard, getting this radio to this condition takes a lot of elbow grease, but well worth it i am a great lover of bakelite sets, watch out for my latest restoration of a 1939 gec
Mark
Old 6th Aug 2008, 9:44 pm   #5
Mark the Mender
Well done Mark a really nice set
Mark the Mender is offline
