Old 10th Nov 2018, 3:14 pm   #1
Geneman14
Default Braun SK6 – connecting external speaker
I'm looking for some kind of adapter that will allow me to connect my old braun SK6 to an external amplifier.
Please see attached – is it possible to connect the black two pronged plug on the right of the image (don't know what these are called) to an adapter that will then send the audio to an external amp/speaker set up instead of the built in internal speaker?
Geneman14 is offline
Old 10th Nov 2018, 3:56 pm   #2
dglcomp
Default Re: Braun SK6 – connecting external speaker
The round DIN connector (marked with the tape symbol) is probably your best bet at it generally has both an input and output on that connector for rec/playback from a tape machine (designed (in this case I would guess) primarily to be able to record radio programmes).
Cables are freely available for this purpose as the same connector/pinout was used on a lot of devices. Just look for a DIN to RCA plug, one with 4 RCA plugs being the most flexible, or just make your own.
dglcomp is offline
Old 10th Nov 2018, 4:50 pm   #3
This https://www.amazon.co.uk/dp/B01N0PYY...a-445380327055 will do admirably two of the plugs will have audio on them, the other two will be inputs.
Old 10th Nov 2018, 4:55 pm   #4
Geneman14
Amazing!
Thanks for the replies.
Old 11th Nov 2018, 2:21 pm   #5
roffe
The Braun SK6 has rather unusual loudspeaker connections.
See my post here:
https://www.vintage-radio.net/forum/...d.php?t=128959
roffe is offline
Old 11th Nov 2018, 9:03 pm   #6
Geneman14
Thanks roffe, I had already seen your post. I'll try the above mentioned DIN to 4 RCA cable and report back. I have a feeling this solution seems too simple to be true!
Thanks again
Old 12th Nov 2018, 9:55 am   #7
rontech
Back in about 1960 I had a Telefunken mono tape recorder with a similar DIN line level in/out socket. A simple DIN to RCA cable worked fine with my main hi fi amp & speakers.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 16th Nov 2018, 8:24 pm   #8
Geneman14
So there's good news and bad news...
The good news is I have sound out of the Braun and into my amp using the DIN connector as described above. The bad news is I'm only getting one channel. Also the output is very quiet.
Any other ideas?
Thanks
