10th Nov 2018, 10:43 am | #1 |
Transistor radio repair. Advice please.
Forgive me if some of my questions are a little naive but I am a beginner and new to this forum!
Just retired so looking for a new hobby and have been given free two radios ( Roberts R404 and Hacker RP70 Ranger) as spares or repair. I have basic DIY skills so hope to restore both but need some guidance as what is best to do On powering up with new pp9 s both work to a fashion but have issues Roberts: some cosmetic issues but seems ok otherwise apart from crackle every time volume knob is changed Hacker: both band switches seem intermittent. One big problem is that the bar (graphite?) with aerial windings is snapped – can it be glued together? Are there other general servicing things I should do? Is there a basic guide to restoration/repair? Thanks in advance for any help |
10th Nov 2018, 10:47 am | #2 |
Re: Advice please
The first thing to do is to obtain some contact cleaner such as Servisol 10 and give all the switches and pots a squirt. You will need to get the cleaner inside the pots through a hole or aperture. Don't use WD40 for this.
The broken ferrite rod can be glued back together with Superglue, assuming the break is clean. Both these models do have some known issues but it doesn't sound as if yours are affected. The R404 uses the AF11x series of RF transistors which are prone to failure, and the RP70 uses the Lockfit series which can also fail but for different reasons. There are lots of threads about these issues if you search the forum. |
10th Nov 2018, 11:04 am | #3 |
Re: Advice please
OK thanks for the rapid response. I will get some contact cleaner and report back soon!
10th Nov 2018, 11:09 am | #4 | |
Re: Advice please
Some info here (towards the bottom of the page) on transistor radio restoration and repair.
10th Nov 2018, 11:13 am | #5 |
Re: Advice please
Graham (Radiocruncher) has published a large number of excellent restoration videos on Youtube ....
https://www.youtube.com/channel/UCDj...t108Cjw/videos He is particularly interested in Hacker and Roberts sets but will tackle all sorts of things.
Regards, John. |
10th Nov 2018, 2:24 pm | #6 |
Re: Transistor radio repair. Advice please.
Hi there and welcome to the forum.
Regarding the broken ferrite aerial rod, if the break isn't covered by one of the coils, my usual way is to superglue it back together and cover the join with suitably sized adhesive lined heatshrink tubing. Not always possible if the break is in an awkward place. Good luck with your new hobby. Regards. John |
11th Nov 2018, 1:43 pm | #7 | |
Re: Advice please
The inductance is slightly reduced (more the wider the gap) which can be compensated for by moving coils away from the rod ends slightly. |
11th Nov 2018, 6:24 pm | #8 |
Thanks for all of the advice.
A few hours in the shed this afternoon ferrite core repaired and contacts cleaned. A few cosmetic repairs and cleaning and Hacker now working perfectly and looking not too bad for a first project |
11th Nov 2018, 10:10 pm | #9 |
So there you go. A success story! You've learned a bit and built up the confidence to try something a little bit more next time if you want to.
11th Nov 2018, 10:22 pm | #10 |
Beware though that the satisfaction of revitalising other folk's forlorn cast-offs can become worryingly addictive- the excuses for acquiring ever more "old junk" become less and less tenable....
