27th May 2020, 9:36 am | #1 |
Help with resistor value
Hello, i'm currently looking at an ULTRA T401 chassis. I'm having difficulty trying to work out what the colour marking are on a resistor, Trader sheet 859, R8 "diode load". According to the sheet it should be 470k. But it measures at 1m ? However i can't make the colour on the resister match either or even close!, maybe a 520k?
I've attached a picture, it's the mostly blue one - can anybody tell me how to read the value please? Derek |
27th May 2020, 9:44 am | #2 |
Re: Help with resistor value
Body looks blue. 620K, a standard value.
These types frequently go high with age, in my experience. |
27th May 2020, 9:55 am | #3 |
Did I imagine a reply from StationX? Reference to body tip spot?
27th May 2020, 10:01 am | #4 |
It seems to have a grey band on the right-hand end, in which case it's 680k and the red blob is a (red) herring.
27th May 2020, 10:04 am | #5 | |
Had there not been follow up posts I'd have edited it giving a reason.
27th May 2020, 10:11 am | #6 |
Could be the underlying body colour. A little extra scratching would confirm.
680k would be a logical E6 20% value whereas 620k would be an unlikely E24 5% one.
27th May 2020, 10:13 am | #7 |
680k...Body, end band, middle band......no other end band so +-20% tolerance.
Lawrence. |
27th May 2020, 10:39 am | #8 |
680k sound like a plan to me!, thanks everyone.
27th May 2020, 11:45 am | #9 |
Hi!
Other than in test instruments, it was exceptional to use a 5% tolerance resistor in most consumer equipment of that era - it was often called up specially in the components list or circuit diagram when needed! Therefore, unless especially called for otherwise, you need only consider the E12 series of values (1.0, 1.2, 1.5, 1.8, 2.2, 2.7, 3.3, 3.9, 4.7, 5.6, 6.8 & 8.2 and decades up) when repairing pre-1965 valved equipment. The red blob on it is simply a blob of locking paint that happened to fall on the resistor's body. Chris Williams
27th May 2020, 2:15 pm | #10 |
There was a slight variation to the old 'body tip band' coding which was 'body tip spot'. Same protocol though so the main body is the first number (in this case 6), the tip is the second number (grey so 8) and the band is the third colour (yellow so 4 zeros). Gold or silver at the opposite tip would have meant 5 or 10 percent.
Just as well that this method of coding wasn't used for the modern 5 or 6 band resistors which I find totally confusing.
