22nd May 2020, 5:01 pm | #1 |
Philips 274A question
The speaker baffle on the above receiver is set back from the grill due to it's mounting to the corner verticals. This seems an odd arrangement but I assume it was a design "feature". Is there supposed to be a gasket of any sort between the two to hide the edge of the cloth when viewed form above and prevent the ingress of dust/debris? Any advice appreciated.
22nd May 2020, 8:03 pm | #2 |
Re: Philips 274A question
I'm pretty sure I had the speaker out of mine when I restored it over 14 years ago. I don't remember a gasket of any kind. If I can look this weekend, I'll see if I can take pictures.
22nd May 2020, 9:57 pm | #3 |
OK had a look tonight. You are correct. There appears to be a felt gasket or similar between the baffle board and the cabinet front. The gasket appears to be about 1/4" thick.
When I restored mine, I didn't need to take the baffle out, only the speaker. I suspect if I did, the gasket would disintegrate so I have no intension of trying! Difficult to get a good photo. This was about the best after around six attempts. It's definitely felt or similar, I prodded it gently with a screwdriver. It's mounted like that to reduce/prevent rattles....they thought of things like that in those days....! It was a good excuse to run mine up after about four months.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 22nd May 2020 at 10:10 pm. |
22nd May 2020, 10:38 pm | #4 |
Many thanks, Sideband. It was kind of you to take the trouble to post a photo. Clearly the gasket in mine has been removed at some point. I shall have to find some suitably thick felt.
23rd May 2020, 7:04 am | #5 |
You will probably find that the gasket is slightly thicker than that and compresses slightly when the screws are tightened. It's all to do with damping resonance.
23rd May 2020, 7:02 pm | #6 |
One remaining problem. To quote from a rather poor music hall joke; "Where do you get felt?"....
23rd May 2020, 8:30 pm | #7 |
Where to get felt? If not a craft shop then a piano supplies shop should have 'damper felt' (that's damper as in silent, not wet).
23rd May 2020, 11:17 pm | #8 |
Found this on ebay https://www.ebay.co.uk/itm/FELT-FABR...ZHfJjrLEnUySrQ
A couple of layers should do the trick. No discussion on the eBay listing though. Link provided for reference only.
24th May 2020, 9:21 am | #9 |
Thanks again, Sideband. I failed to spot that one when I searched the site. Also might try a local upholsterer who lives in our village.
24th May 2020, 7:12 pm | #10 |
Lets see your solution when you find suitable material (and it all works of course)!
