22nd Dec 2009, 11:27 am | #201 |
Re: Newb Stumped on a Derwent
SPLITTING THE BIAS.
The 75 needs a bias of -2V and has a specified anode current of 0.9mA. 2/0.0009 is 2222R, so I'll use a 2.2K cathode resistor. I'll bypass the 2.2K with a 25uF capacitor, because that's what's used in the GEC 4750, which also has a 2.2K cathode resistor for the AF amp. I'll leave the 0.0033uF between anode and cathode, as that's how the 4750 does it. Not very scientific I know, but it should provide a starting point. ------------------------ 1. Disconnect the 0.0033 capacitor from the junction of the 330R and the 50uF capacitor. Reconnect the disconnected lead directly to pin 5 of the 75. 2. Remove the wire between pin 5 of the 75 and the junction of the 330R and 50uF. 3. Connect a 2.2K resistor between pin 5 of the 75 and chassis. 4. Connect a 25uF capacitor between pin 5 of the 75 and chassis. Negative end to chassis and positive end to pin 5 of the 75. 5. Power up and measure voltages:- Chassis to pin 5 of 42. Should be about 15V Chassis to pin 5 of 75. Should be about 2V. Report results. 6. See what hapens if you inject a signal at the PU socket. 7. See if the radio works. --------------------- I'd wait a while for other member's comments on this post before starting work.
22nd Dec 2009, 11:44 am | #202 |
Sketch showing suggested modifications attached.
22nd Dec 2009, 11:49 am | #203 |
Hi Station X
which electrolytic would best suit? The last one just has u not uF is that pico |
22nd Dec 2009, 11:50 am | #204 |
sorry picture this time
22nd Dec 2009, 11:52 am | #205 |
Bottom one is fine. There is a wire that runs from 75 pin 5 into the IF transformer. Make sure you leave that connected to pin 5.
22nd Dec 2009, 11:53 am | #206 |
22nd Dec 2009, 11:53 am | #207 |
Seconded. There'll only be a couple of volts across it.
22nd Dec 2009, 11:55 am | #208 |
22nd Dec 2009, 11:59 am | #209 |
2.2k red,red,blue.green?
22nd Dec 2009, 12:01 pm | #210 |
Red, red, red plus a tolerance band.
First figure 2. Second figure 2. Number of zeroes 2. Check with a meter
22nd Dec 2009, 12:10 pm | #211 |
Only have 2.7 or 1.8
22nd Dec 2009, 12:12 pm | #212 |
Go for 1.8 then.
Brown, Grey, Red?
22nd Dec 2009, 12:15 pm | #213 |
yes
22nd Dec 2009, 12:24 pm | #214 |
Plenty of knowledgable members have viewed the suggested modifications without making any adverse comments, so I'd go for it.
I'll refrain from making any predictions about having it working by tea time. That backfired yesterday.
22nd Dec 2009, 12:26 pm | #215 |
Ok off we go then, iron warming up
22nd Dec 2009, 12:55 pm | #216 |
Ok it's much better now, fade off cured
lots of gain stations tune in however lots of background noise and voices are raspy Station X you the man |
22nd Dec 2009, 12:56 pm | #217 |
just going to check voltages now
22nd Dec 2009, 12:59 pm | #218 |
Voltages?
Clean the wavechange switch, speaker plug, valve pins, volume and tone controls. Is the distortion still there when using the PU socket? If so that would indicate that the problem is in the AF stages. If not it's further back in the IF or RF stages.
22nd Dec 2009, 1:26 pm | #219 |
voltages Valve 42 pin1.....11vac pin2.....260vdc pin3.....270vdc pin4.....2vdc pin5.....16vdc pin6.....0 Valve 75 pin1.....0 pin2.....150vdc pin3.....VVM set to 1.5v read 4 on the scale pin4.....2vdc pin5.....3vdc pin6.....11vac I noticed that heater pin6 on the 42 and heater pin1 on the 75 read 0. Looking at the physical wiring. there is as follows Physical wire from 42 pin1(H)........... to pin6(H) on the 75 Physical wire from 42 pin6(H)........... to pin1(H) on the 75. interesting that the link between 42 pin6 and 75 pin1 both read 0 (wiring fault?) signal added to P.U. and Vol pot, distortion is still present and all sorts of sounds. reminds me of a kid listening to radio luxembourg remember the inteference. Last edited by oldticktock; 22nd Dec 2009 at 1:52 pm. |
22nd Dec 2009, 1:51 pm | #220 |
You have to measure heater voltages by connecting your meter on the AC range between pins 1 and 6. Don't do this with your VVM though.
42 readings are fine. I'm still thinking about the 75.
