8th Nov 2021, 11:01 pm | #321 | ||
Re: Commodore PET 2001 voltage regulators
I have a spare sticker which I think is left over from inside the monitor. You couldn't do me a favour and photograph the stickers inside the monitor case could you? I should have been paying more attention...
Colin. Quote:
8th Nov 2021, 11:07 pm | #322 |
I’d also recommend a phosphoric acid rust remover to remove some of the rust and neutralise the rest. It might also be worth cleaning with t-cut, rust spots tend to stain the surface of the paint over a larger area than the rust itself. Both should be available from a local car accessory shop.
8th Nov 2021, 11:19 pm | #323 | |
Alan |
8th Nov 2021, 11:35 pm | #324 | |
Alan |
9th Nov 2021, 11:58 am | #325 | |
It'll be interesting to see how Tim approaches the rust issue. Last step in a very worthwhile journey. Just a quick update on the progress of my Chinese chips (aka MC3446s) which have been allocated a SpeedPAK tracking number but are not yet shown as being in transit. Estimated delivery date 24th Nov to 2nd Dec. Alan |
9th Nov 2021, 12:40 pm | #326 |
I seem to recall the texture on my (early) pet looked like the picture, but maybe it was a little finer-grained. I know the later PETs with plastic panels were much flatter in finish because I also have a 3032 with the plastic case and this was something I noticed.
9th Nov 2021, 1:23 pm | #327 |
Am I right in remembering that you haven't seen your PET for a while Slothie? If my 2001-8 is anything to go by the finish is nowhere near as heavily textured as the woodchip version but who knows what went on in the office furniture factory. Anyway enough of this digression as I've already spent far too much time typing forum posts today.
Alan |
9th Nov 2021, 2:03 pm | #328 | |
9th Nov 2021, 2:40 pm | #329 |
I imagine all the early chiclet machines were US imports. Mine certainly says 'Made in the USA' on the serial number label. Here I go again. Time to shut down the tablet.
Alan |
9th Nov 2021, 6:17 pm | #330 |
I've never owned or used one of these and I'm not really in the market for one but if one fell into my lap, I would be be so disappointed if it turned out to be in working order.
The available information is so comprehensive and so complete that it makes them a real pleasure to work on, even from a distance. |
9th Nov 2021, 6:25 pm | #331 |
To be fair that applies to a lot of computers from that sort of period
Back at the time I was a TRS-80 user, not PET. But there were/are full technical and service manuals with circuit diagrams, theory-of-operation, etc sections freely available for all the TRS-80 machines and peripherals. And look at the DEC PDP8 and PDP11 manuals for the TTL-based machines at least. A manual of circuit diagrams. A manual of how it works at component level. A manual of exploded diagrams and parts lists. And so on. Yes, the manuals just for the CPU take up quite a bit of shelf space, but you can read how it all works. |
9th Nov 2021, 6:35 pm | #332 | |
Alan |
9th Nov 2021, 6:42 pm | #333 | ||
I'm waiting for the next one to turn up on here. There's a good team of fixers now.
Colin. Quote:
9th Nov 2021, 7:18 pm | #334 |
I have to say that Daver2 (author of one of the PET test EPROMs we have been grateful to have the use of) has been 'doing' epic PET repair threads over on the Vintage Computer Forums for a lot longer than we have here.
It's possible that he is also a member here but he obviously likes where he is, and let's be honest, the VCFED forum is a more logical place to conduct that type of thread. But as Colin said, we have gathered quite a good little group of PET owner / drivers and other interested individuals here with a fair bit of actual, practical and technical experience between us, and most of all we take as much time and work at whatever level the OP needs us to, as long as the OP is able to work patiently and methodically and report results back. My growing impression is that PETs in particular naturally seem to attract that sort of person, which greatly increases the chance of a successful outcome. |
9th Nov 2021, 9:06 pm | #335 | |||
Tim. |
9th Nov 2021, 9:15 pm | #336 |
I've been doing some more cleaning today, and it looks like most of the surface rust spots could be staining. I've attached a picture after cleaning (should really have taken one before!), but it show a couple of very small marks.
I think I'll continue with this and give the case a really good clean and then see how everything looks. I may have been a bit too critical, but after the cleaning so far, the case doesn't look too bad as most spots seem to be coming off. It could be the T-Cut which was recommended may also be something to try. I certainly don't think a respray is required for the main casing (nor monitor (outer) case). However, I don't think I'll be able to get away with that on the inside of the monitor casing. I tried a light scrub near the back, and it's quite rough; so I think it will need some chemical help. It looks to just be the bottom of the casing (as the sides/top look clean), but something will need to be done. So I think I may yet ahve to look at removing the monitor casing from the main casing, then trying to remove the PCB/CRT. I'm not looking forward to this! Tim. |
9th Nov 2021, 9:39 pm | #337 | |||
That's great - thanks very much. Gives me a good idea where to put mine back.
I'm guessing it's the initials of the person qho QC'ed the monitor PCB, but I can't be sure. Colin. Quote:
9th Nov 2021, 9:49 pm | #338 | |
Getting the monitor case off the PET case is easy - undo four nuts inside the PET Motherboard case at the top. Make a note (photograph) of any cables before you unplug them; you'll have to unplug the monitor cable from the motherboard at least.
And please look up discharging CRTs before you go any futher. Even if you're not planning on touching the CRT, you might do so by accident. Here's my discharging tool, and also a couple of videos that are worth watching. https://www.youtube.com/watch?v=x1DeMOl_nK4 https://www.youtube.com/watch?v=mParOYnZ3Fw If you go through the thread for my PET work, start at post 1767 (!) for all the helpful advice I was given. Colin. Quote:
9th Nov 2021, 10:08 pm | #339 |
Although the tube voltage (thousands of stored volts) sounds fearsome, if you are unlucky to make contact with it it will just feel like a nasty static shock. You are more likely to hurt yourself physically by trying to whip your hand away across sharp bits on the PCB or chassis.
The real danger is to other components in the machine - if the earth clip slips off and goes on a wander across the circuit board at the very moment you make contact with the high voltage then the tube will discharge into whatever the clip happens to be dangling next to at the time, so I can't stress enough, the earth end of the discharger must be absolutely securely connected to the earthy part of the tube with no possibility that it will slip off while you are attempting to discharge the tube. |
9th Nov 2021, 10:13 pm | #340 | ||
Regarding the aligator clip. Is there a recommended earth point on the PET, or do you use one near the CRT? Tim. |
