17th Oct 2020, 10:18 am | #1 |
Valve Amp Identification?
Could anyone shed some light or give any info on this Amp? Hopefully The photos provide a clear picture.
All help welcome. Thanks |
17th Oct 2020, 10:49 am | #2 |
Re: Valve Amp Identification?
It looks like a home-brewed one-off to me!
17th Oct 2020, 10:54 am | #3 |
Chassis is nicely made but the wiring is definitely functional home made. Components say mid late fifties very early sixties.
Seems to be missing a PSU. |
17th Oct 2020, 11:04 am | #4 |
Seperate PSU required?
17th Oct 2020, 11:19 am | #5 |
It appears to have smoothing capacitors. Is that a a mains transformer or an output transformer?
17th Oct 2020, 11:23 am | #6 |
Is it safe to assume that it is an audio amplifier for loudspeakers and not a modulator for a transmitter?
17th Oct 2020, 11:24 am | #7 |
Looks like ultra linear, the b7g valve looks interesting.
Lawrence. |
17th Oct 2020, 11:30 am | #8 |
EL90 or N78? could be a screen regulator for the EL34s.
However there is a corresponding empty base on the other side. |
17th Oct 2020, 2:59 pm | #9 |
Are those 3 vertically mounted pots used for varying the valve/s bias?
Edward. |
17th Oct 2020, 5:40 pm | #10 |
Thanks guys... your help is gratefully appreciated.
17th Oct 2020, 6:53 pm | #11 |
Looks ultra-linear pair of EL34s. Power must be from something external.
Surprising number of trimmers. I wonder if this is not self-biased for max power and efficiency. The switches are mysterious. Measurement of transformer turns ratio should show whether it's for driving a speaker or modulating a transmitter. Modulating a full legal power transmitter usually took a pair of KT88 to do comfortably, producing 100W You hd atransmitter with 150W DC input (legal limit) which meant about 100W output and 400W PEP, so the modulator had to boost the TX power rather dramatically. With a pair of EL34, it was a harder task. I'd guess it was a modulator. Interesting what the transformer might be THe Woden UM series are easily recognised. Full welly transmitters would use something like an 813, and the mod transformer secondary and all cabling from it would be up in the 2kV region with deadly current availability. This looks to be from someone getting their power up, but a bit below the licence limit. David
18th Oct 2020, 8:10 am | #12 |
Interesting beast. That looks like just the amplifier that needs a separate PSU. looking at it closely there seems to be a balance pot on the OP to either balance AC or set bias, there's a wire to it from the chassis plug. But then and again there's two big resistors (150r?) on the OP valve bases which with the the 16u caps could mean it's cathode biased.
The balance/trimmer pots, possible screen regulation and what looks like a zobel R/C on the OP point to an audio amp, g2 wouldn't be regulated in a TX would it? If you could trace the circuit out that'd be great, it looks a really interesting amp, if not the OPT, if that's what it is looks nice and chunky. Andy.
