Old 27th Apr 2017, 8:24 pm   #1
els1967
Default Mic won't work on Tele 310
As above, I just can't get the mic to work. Have tried the handset on a different phone and it works fine so it can't be that. I've traced out all the connections on the phone and get continuity on everything. I also get a dial tone. I've bridged out the dial between D4 and D5. A visual inspection shows the wiring to be in good condition. The only odd measurement was around 50 ohms on the induction coil between 3 and 4.
I'm guessing I might have to solder in a new induction coil but I just wanted to make sure I wasn't missing anything obvious.
On the diagram (N410) I've connected my phone cords to T1 and T8 and bridged T1 and T2. I've got my own PBX.
Any ideas?
els1967 is offline
Old 27th Apr 2017, 9:19 pm   #2
ThePillenwerfer
ThePillenwerfer's Avatar
Default Re: Mic won't work on Tele 310
To be honest I can't make much sense of N410. However, similar instruments have the 75Ω part of the coil in parallel with the receiver and 30Ω non-inductive resistance which would lower the resistance reading between coil terminals 3 and 4 if these weren't disconnected first.
ThePillenwerfer is offline
Old 27th Apr 2017, 9:30 pm   #3
els1967
Ok thanks.
els1967 is offline
Old 29th Apr 2017, 3:27 pm   #4
els1967
Traced it to a short on the 0.1uF cap. thus shorting out the speech network. Odd as it's not often these fail. Does anyone have a spare square one?
els1967 is offline
Old 29th Apr 2017, 4:03 pm   #5
ThePillenwerfer
Thanks for the up-date; I'd been wondering about it.
I doubt it would matter if you left that cap disconnected. You could also replace it with a normal modern one, but it's a different matter if you want to keep things original. Another option would be re-stuffing as there'd be plenty of room.
Old 29th Apr 2017, 4:42 pm   #6
russell_w_b
russell_w_b's Avatar
All that cap is for is to bypass any RF if you're located near a transmitter and the carbon mic decides to act as a demodulator.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 29th Apr 2017, 9:36 pm   #7
els1967
Well the most interesting part was finding the fault. I've got a few spare GPO caps around, prob. will fit one then shove it in the attic tbh.
els1967 is offline
