Old 18th Jul 2019, 12:55 pm   #1
greg_simons
greg_simons's Avatar
Default Suitable high voltage sealant for tripler Rebuild?
Seeking some advice from more knowledgeable people here, i may have to rebuild a tripler for the thorn 2k, the problem is sealing it up afterwards, back in the day this was a jelly like substance that could be easily scraped out if further work was needed, does anyone know of a suitable product that can withstand kigh voltages yet can be easily undone like the original material, all i know for certain is acetyl cured silicone is not suitable, there is a product called silcoset but the cost is horrific for one small job.
Greg.
Picture, sound?, DOOR.
greg_simons is offline
Old 18th Jul 2019, 1:16 pm   #2
FRANK.C
FRANK.C's Avatar
Default Re: suitable high voltage sealant for tripler bebuild
There are some silicone's that don't give off an acidic gas as they cure. I needed some years ago and it was a 'all weather' type that I found OK. To test I would put some of the silicone along with a piece of copper wire into a zip lock bag and leave for a few days. If it gave off an acidic gas the copper would turn green. You could almost tell by the smell they give off as they cure.
Frank
FRANK.C is offline
Old 18th Jul 2019, 1:27 pm   #3
mickm3for
Default Re: Suitable high voltage sealant for tripler bebuild?
Hi R T V silicone CPC
mickm3for is offline
Old 18th Jul 2019, 1:29 pm   #4
Goldie99
More generally, they're called 'neutral cure' silicones
Goldie99 is offline
Old 18th Jul 2019, 7:57 pm   #5
cheerfulcharlie
Used for sealing underground cables after splicing two pack 'Scotchcast Resin 8882 '
can be broken into in the future to say re-route the cable.
About the cheapest (of it's type)around at approx £20
cheerfulcharlie is offline
Old 19th Jul 2019, 8:17 am   #6
greg_simons
Many thanks for the info, surprisingly enough using neutral cure silicone as the key search word brought up a lot more than the usual bath sealant, just shows you have to know what you're looking for.
Greg.
Old 20th Jul 2019, 4:06 pm   #7
greg_simons
Default Re: Suitable high voltage sealant for tripler Rebuild?
No more input to this thread plus i have the required information, this can be closed thank you.
