13th Mar 2020, 9:18 pm | #1 |
Grundig 2×4 super - Tape loading mechanism
Just a quick query at this point.
The tape loading mechanism doesn't work on this machine. I have the lid off and am having a good look inside. On the right there are two white cogs next to each other, one of which clearly winds the tape tray up and down. The one next to it is, i expect, in contact with something unseen underneath. Unlike the above mentioned right, the left side of the loader only has one white cog which is in contact with the lowering mechanism. There doesn't seem to be one connected to it's left. Is this normal for this machine? Thanks. |
13th Mar 2020, 10:09 pm | #2 |
Re: Grundig 2×4 super - Tape loading mechanism
Do you have a picture? i can check it on my Grundig 2x4s if so unless someone can answer this without taking to lid off.
Oh I've had that for years dear!! |
13th Mar 2020, 10:30 pm | #3 |
Is this one of those machines that has bulbs and light sensors to detect the tape position? If so the fault may be caused by a blown bulb. Memory of 2x4s is hazy I'm afraid.
Alan |
13th Mar 2020, 10:53 pm | #4 |
No idea. I'm not clued up on how it works. No visible fault or breakage, tape loader just doesn't work. Trying to figure out why not. The cogs thing seemed the most obvious place to start
12th Apr 2020, 11:45 am | #5 |
After having a good look at it again, I'm pretty sure it's not a broken/missing cog. The single cog on the left is noticeably wider than the two on the right. I'm pretty sure it's supposed to be like this. What has become obvious is the complete and utter lack of any kind of noise or movement from within the machine, whcih leads me to conclude that it's some kind of power issue. ONe of the main buttons, the 'tape' one I think, can have a flashing red light above it if I press it, but other than that, there's ablsolutley no sign of power being present in the machine. If it was just a jammed loading mechanism, surely it would make some kind of noise while it still tried to do something with it?
13th Apr 2020, 5:08 pm | #6 |
I believe V2000, like Betamax, uses metal sensors to detect the end of the tape. At least my V2000 tapes have an aluminium strip at the beginning and the end. Unfortunately I don't have any V2000 VCRs so I don't know for sure.
14th Apr 2020, 11:47 am | #7 | |
https://www.youtube.com/watch?v=do6AwRCOzv8 https://www.youtube.com/watch?v=fKjSgiBRxic https://www.youtube.com/watch?v=31zwKvJpVf8
