20th Jul 2020, 4:39 pm | #1 |
Heathkit V-7AUK VTVM HT help needed
I swopped out the original 16uf filter cap for a 22uf and changed the rectifier (which I thought was big diode but turned out to be a selenium rectifier) for a rectifier diode ( it's half wave )
The voltage is higher than it should be by a few volts ( should be between 50v and 70v on the positive side but has increased to 74v and between 60v and 85v on the negative side but has increased 93v.It has calibration presets but will the meter accuracy be affected by the difference in voltage? Do I need to add a dropper resistor of about 100ohms or so to bring the HT down? |
20th Jul 2020, 5:33 pm | #2 |
Re: Heathkit V-7AUK VTVM HT help needed
Hi!
A resistor of 1k ohms 5W in series with the rectifier should be suitable! The wattage rating I suggest is quite a bit higher than is really needed for the h.t. current being drawn, but a 5W ceramic–cased or one of the aluminium–clad type that will bolt to the chassis will run relatively cool in operation – there is quite a larger component of a.c. ripple–current flowing into it for the reservoir capacitor, to allow for, as well as the d.c. component of anode–current of the two valve sections! The double–triode balanced valve–voltmeter circuit is relatively insensitive to h.t. and l.t. (heater) voltage variations, and this why it is so popular, finding use in virtually all commercial manufactured instruments, however you still don't want more h.t. voltage than Heathkit specified if you can avoid it, as keeping the h.t. to a minimum in these low–current valved circuits will minimise heat dissipation and warm–up drift. Chris Williams
20th Jul 2020, 5:39 pm | #3 | |
Was the selenium rectifier faulty? When I rebuilt my V-7AU I decided that the rectifier was fine, so I left it in circuit. You could also just go with what you have now got and see if the VTVM will calibrate properly. It might just be ok. Colin. |
21st Jul 2020, 2:50 pm | #4 |
I tried 1.5kohms 3watt and it knocked it down a few volts to 69v+ and -89v so maybe ok for the time being.
Are those test sockets standard 4mm (banana) as I need to make up some leads? I'm assuming I can calibrate it with a 1.5v battery (in the absense of the calibration battery) and 110v ac adapter as I have an accurate dmm. |
21st Jul 2020, 3:42 pm | #5 |
I believe the calibration battery is 1.55vdc which I should able to replicate with an adjustable power supply.
21st Jul 2020, 6:49 pm | #6 | |
As it happens, the sockets on my V-7AU are 4mm and I simply bought a couple of standard test-leads from Maplin. Some banana-plugs may be a bit long for the sockets, but this may not bother you too much. Don't forget that the the DC socket is a 1/4" jack and needs to have a 1M0 resistor fixed so that it is close to the tip of the prod. The lead itself is screened and the screen earthed at the VTVM end. I am assuming that you have a manual for this, but in case you don't, I can let you have a pdf copy, if you wish, just ask. Colin. |
22nd Jul 2020, 11:02 am | #7 |
I have an alkaline cell but its 1.609v not 1.5
22nd Jul 2020, 5:01 pm | #8 | ||
22nd Jul 2020, 5:36 pm | #9 | |
Incidentally, some of these manuals are tricky to find. This one was produced for the US market and mentions 105-125 VAC and "tubes". The issue over the battery is based on the chemistry - a zinc chloride battery gives 1.55V, but an alkaline gives a slightly higher no-load voltage, as you have found. If you have problems finding a fresh zinc chloride battery, try Poundland (who sell packs of Kodak ones at - surprise - £1 each). Maybe Poundland isn't open yet, but you could try Wilko or somewhere similar. A supermarket might be a possibility, too. Just make sure that the chemistry is zinc chloride. Batteries in local convenience stores may be a bit old and rather expensive. Colin. |
24th Jul 2020, 11:18 am | #10 |
Mine had a large wax capacitor 0.05uf 600vac in the middle which had melted. I replaced it with a 600vac 0.068uf, however I noticed in the manual it states 0.01uf 1600v (must be DC) but mine is rated at 1250dc.
24th Jul 2020, 2:49 pm | #11 | |
https://www.justradios.com/cart.html I have bought stuff from Dave and he is good. No connection other than a satisfied customer. Something I should have added is the strong suggestion to change the mains cable for a proper three-conductor type, so that you have an earthed test instrument. While you are doing that, fit a proper cable restraint, too. The original Heath arrangement is truly lethal (just a knot in the cable that goes through a rubber grommet). Unless, of course, you have a liking for getting mains shocks off your test-gear. Colin. Last edited by ColinTheAmpMan1; 24th Jul 2020 at 3:03 pm. Reason: More info. |
25th Jul 2020, 10:42 am | #12 |
I understand that earthing the chassis can cause some problems.
Have you seen this article? http://www.heathkit.nu/heathkit_nu_V-7A.html BTW he puts the 1 Meg resistor inside the case but shouldn't it be nearest to the tip of the probe? |
25th Jul 2020, 1:31 pm | #13 | |
Regarding the DC probe, yes it is normal practice for the probe resistor to be close to the probe tip. I can only think that this is still concerned with floating measurements, but I might be wrong. Consider this; if you are making measurements on a 1500 VDC point using the 1500 V scale and a normal, unscreened test-lead and without the probe resistor at the probe tip, then the voltage under test is running right from the probe tip to the instrument input with only the insulation of the lead to stop you getting a shock. I don't think this is either good or sensible modern practice, but that might just be me wanting to live a few more years. I tend to take stuff like this with a pinch of salt when there is no rationale given as to why the changes are made. That is not to say that some modifications shouldn't be made, such as the horrid original Heath cable restraint (a knot indeed!). If this chap had wanted to make floating measurements with a high-impedance input meter, why didn't he just buy a decent modern DMM? Colin. |
25th Jul 2020, 2:47 pm | #14 |
"While you are doing that, fit a proper cable restraint, too"
What type do you favour for a 3 core cable? I have a couple of heathkit cases to do. |
26th Jul 2020, 6:35 pm | #15 | |
https://www.ebay.co.uk/itm/Strain-Re...cAAOSwLVZV4HqR The hole might need to be enlarged and and it should ideally be a round hole with two flats, one on each side. If the cable is at all large, they can sometimes need some persuasion, but you can probably rest reassured that if it requires that much effort to assemble, it will need just as much to let go of the cable. I should probably admit that I haven't yet used one of these on my V-7AU yet, but I did make an improvement to the original. Perhaps that should be one of my next jobs. Stop Press: I have just sorted my V-7AU with one of these restraints and it was a pig of a job, but much better and safer. The hole needed altering and enlarging and re-assembling the battery-holder with the earth-connection isn't easy. Colin. |
