Reply
Old 10th Feb 2019, 11:52 pm   #221
InsertNameHere
InsertNameHere's Avatar
Default Re: CRT is brighter to one side [Hitachi CTP213]
Okay, thank you, I think I may have some photos, but I'll check, and i'll take some more up close shots, to help - though that will probably have to be tomorrow.
The slant is only a small angle, but as I've said, it's noticeable, though I can live with it if need be.
Thanks
InsertNameHere is online now   Reply With Quote
Old 11th Feb 2019, 1:11 am   #222
Lloyd 1985
Lloyd 1985's Avatar
A fix that doesn’t involve taking the back off the set: put some bits of cardboard under one end of the cabinet, repeat until picture is level!!
Only joking, personally I’d leave it alone, as the set is working well now, and you can cause convergence errors by messing the scan coils/ yoke about, I know wonky pictures can be annoying though! I’ve twiddled many yokes to try and level a picture.
Regards
Lloyd
Lloyd 1985 is offline   Reply With Quote
Old 11th Feb 2019, 1:43 am   #223
InsertNameHere
I’m glad you were joking as it’d be just my luck i’d lift one side of the set up to wedge some cardboard underneath and the set would slide off the cabinet onto the floor. (Im only joking, too)
I don’t want to mess the set up again, but i am slightly OCD so the wonky-ness does annoy me quite a bit. Wouldn’t it be okay though if i were to mark the pots and then adjust the yoke as the set is self convergence as it’s a PIL set.
If theres a chance of really messing it up then i can live with the angle, but i’d much rather straighten it out.
Thanks
Old 15th Feb 2019, 12:13 pm   #224
Station X
Station X's Avatar
39 posts moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=154067
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Old 16th Feb 2019, 10:01 am   #225
Heatercathodeshort
Heatercathodeshort's Avatar
Leave it alone! It's great. John.
Heatercathodeshort is offline   Reply With Quote
Old 16th Feb 2019, 3:05 pm   #226
InsertNameHere
I will do, and have done!
I was just thinking, it wouldnt have really been a problem in the 70s as TV was broadcast in 4:3, and when the TV does show a full screen picture, you wouldn’t notice the wonkiness, along comes 16:9 and you get black bars at the top and bottom - thats when you see it!
Thanks
Old 16th Feb 2019, 8:17 pm   #227
rambo1152
rambo1152's Avatar
Thanks
Don't forget that before the advent of 24 hour TV, the test-card would be shown on one or more channels for much of the day, and some of our customers seemed to have nothing better to do than watch for the slightest imperfections.
Graham.
G3ZVT
rambo1152 is online now   Reply With Quote
Old 16th Feb 2019, 8:28 pm   #228
InsertNameHere
Never gave that a thought, though when watching TV, you usually forget about the imperfections - I do anyway
Thanks
Old 17th Feb 2019, 10:39 am   #229
Sideband
Sideband's Avatar
Dare I mention....some TV's had a 'service mode' and within that menu was an adjustment for 'tilt'....thinking Philips TV's here but Hitachi and others did a similar thing. IF a service mode is available on your set it will either be shorting two particular 'service pins' together or accessible via a service remote or by pressing a certain sequence of buttons.
The method of access would only be given in the service manual. Note also that 'tilt' adjustment was not always possible in service mode.....it depends on the model and how 'upmarket' it was. If such a service mode is available, extreme caution must be used since incorrect adjustments may be detrimental of even damaging.
'Can we have everything turned up louder than everything else'? Ian Gillan...Deep Purple
Sideband is offline   Reply With Quote
Old 17th Feb 2019, 12:55 pm   #230
rambo1152
rambo1152's Avatar
Yes, but Aaron's set is too early for that.
Also I don't think it was impossible not do to do damage using service mode with those sets those sets had it, I can't think of an example with a TV, but I had a Canon camcorder where entering the service mode was done purely from the remote control, and it was possible to make the on-screen display go blank and effectively lock you out. I was careful not to store the result, but it occurred to me a person with nefarious intent, could have easily bricked the Canon camcorders in Currys window, without even leaving their car.
Graham.
G3ZVT
Reply
