12th Sep 2019, 7:54 pm | #1 |
Pilot little maestro 444 mains dropper bother
So as per usual went out to buy a DAC90a came home with that and a 38/39 pilot little maestro 444 now aware that these sets originally used the mains lead as the resistance to drop the voltage to the set obviously this has long since gone and been replaced with a dirty great big dropper resistor haphazardly bodged on to the chassis. Now I have a very nice Stewart Warner c151 obviously an American set and therefore US voltage this plugs straight in to our mains and uses a motor start capacitor as a dropper for the heaters can you do that to this pilot and if so how ? As the current set up is scorching the case .
12th Sep 2019, 7:59 pm | #2 |
Re: Pilot little maestro 444 mains dropper bother
Hi Trabant, have a look on the forum and you should find a reference to capacitive droppers and how to calculate them. Typical values are in the 2 to 4uF range and motor run or X class caps work fine.
There has been discussions about how they will not work correctly, or damage your set if they fail; however, in my experience they present no problems. Ed |
12th Sep 2019, 8:05 pm | #3 |
Is this link any help (scroll down to near the bottom for a capacitive dropper in a little maestro)
http://www.pasttimesradio.co.uk/arti..._projects.html If your set is different, the values will need changing. https://www.vintage-radio.com/repair...per-calcs.html Ken |
12th Sep 2019, 8:34 pm | #4 |
Oh that's exactly what I needed Ed and Ken thanks very much
12th Sep 2019, 8:57 pm | #5 |
Just for information, I replaced the failed dropper in my Pilot Little Maestro model 10 using a capacitor (2.5uF) retrieved from an old fluorescent light fitting. I trimmed the value by fitting a 0.1uF X class capacitor in parallel with it. It's been working for about 10 years with no problems at all.
Ideally you should use a motor run capacitor since these are designed for continuous use and usually rated at around 400V AC. You can trim the value by connecting an X class cap in parallel if necessary. X class caps also seem to work fine in this position....at least I've never had a problem with them. The set will run much cooler with a capacitive dropper.
