25th Nov 2021, 5:15 pm | #1 |
Meter what make is it?
Gifted to me from Freecycle and I was wondering if anyone has one and can give me any info. Maker and manual and what the labels are in top left and right corners would be good.
25th Nov 2021, 5:55 pm | #2 |
Re: Meter what make is it?
Looks like one of those generic types, especially with the extra, unused, button hole. I would just have a play and discover. I do like the three leads!
edit: Just noticed the thermocouple input, that could make it more useful. Last edited by Guest; 25th Nov 2021 at 5:56 pm. Reason: Added a bit |
25th Nov 2021, 9:11 pm | #3 |
I've got a Rapid meter with the exact same casework and range switch as that and also a Proskit with the same case so maybe you can search for an auto range version of either of them
25th Nov 2021, 9:21 pm | #4 |
I was also thinking Rapid, as I've got one similar, also with the thermocouple socket and the thermocouple itself.
25th Nov 2021, 9:28 pm | #5 |
the thermocouple & transistor test socket are in the exact same positions as well
26th Nov 2021, 12:11 am | #6 |
SEAxxxx
Sealey? Generic tools flogged into the economy end of the automotive market? Seaward? David
26th Nov 2021, 8:21 am | #7 |
Good ideas. Does anyone have a manual for the Rapid meter?
28th Nov 2021, 11:35 am | #8 |
One option is marked’ Hz % duty’. What does this mean?
28th Nov 2021, 12:12 pm | #9 |
When that function is selected it will display the frequency of the voltage being sampled, it will also display the percentage duty cycle of the waveform of the voltage being sampled when the %duty button is pressed, which appears to be the bottom left hand Yellow button in the photos, so far as I can make out.
Plenty of info about percentage duty cycle on the web, eg: https://www.fluke.com/en-gb/learn/bl...-is-duty-cycle Lawrence. Last edited by ms660; 28th Nov 2021 at 12:19 pm. Reason: correction |
