Old 16th Mar 2019, 10:11 am   #1
Megatron
Default Taylor 45C Valve tester.
My taylor 45 valve tester always reads high, for examle EL84 tests as 12gm
whereas the data says it should be 8. this seems to be true for other valves too.
I have used it like this for years, just having a golden sample of each valve type I regularly test as a reference. I thought it was time i did something about it.
I opened it up today and see someone has already been in there.
Given that the meter movement is free and all the cathode resistors are ww the only immediately obvious thing i can could see that may have a gross effect on both ranges is the rectifiers on top of the transformer are 1N4007.
Theres a single diode and a made up bridge. I guess these would have been selenium or copper oxide originally is this likely the issue?
If so how best to fix it? I guess it needs some added series R and Vf?
anyone done this before, do you think a zenner and resistor in series would work? if so what sort of voltage drop would I need to replicate the original rec? is this even the likely problem? There doesn't seem to be anything else in the GM test circuit that could drift that much.
I am thinking that if the voltages are all high then the cathode voltage must be high too, therefore when the resistor is shorted the voltage change is greater than it should be??
Should i start with a series ZD say 47 v and see what happens?
Megatron is offline
Old 16th Mar 2019, 2:20 pm   #2
Megatron
Default Re: Taylor 45C Valve tester.
Measured all the resistors and all the voltages and theyre not far off.
also the later testers used silicone diodes and seem to have no other changes......... mor investigation required.
Megatron is offline
Old 16th Mar 2019, 4:29 pm   #3
Megatron
Replaced every resistor and capacitor in the thing and still reads high.
also now has developed another fault, when you switch from gm back to cathode leakage the ecc83 under test flashes over.
what i need is some close up photos of the top right hand selector switch to check its wired correctly and I havent got a resistor wrong...
its not a fault i have seen before whenever i have used it.
the colours on the resistors I replaced were well faded, but I measured them as well and were in the right ballpark figure though had drifted a bit.
replaced them one at a time too so everything should be right, but its a bit messy someone has been in there before.
circuit diagram i have has no resistor values on it.
Megatron is offline
Old 16th Mar 2019, 5:37 pm   #4
sven_swe
sven_swe's Avatar
Hi, below is a link and an attached PDF to schematics I used when trying to find the values for some resistors that were replaced in mine. The component values can be different depending on the time it was made it seems. Mine had different values and it was a mess. I am still not 100% done with it since something has come in between
Manual that includes schematic:
http://www.jogis-roehrenbude.de/Roeh...45C/manual.pdf
sven_swe is offline
Old 16th Mar 2019, 6:32 pm   #5
Megatron
Thanks for that thats quite helpful.
I stopped the wierd flashover changing between gm and leakage, seems the tower of wafers was a bit misaligned allowing a make before break or vice versa.
changed pretty everymuch resistor now and the caps too, but still measures high. or seems to. i have measured many el84 and ecc83 and all the good ones seem to measure EL84 measuring 12.5 as opposed to 8.
Megatron is offline
Old 16th Mar 2019, 8:07 pm   #6
sven_swe
sven_swe's Avatar
Last time I checked my manual had an error for EL84 and that is mentioned in this searchable valve chart that was posted on this forum(they differ often), not sure if that has any influence though:
https://www.vintage-radio.net/forum/...40&postcount=5
https://www.vintage-radio.net/forum/...ad.php?t=66896
sven_swe is offline
Old 16th Mar 2019, 8:24 pm   #7
Megatron
I just measured a load of 6v6 and they measure high as well.
should be 2.6 but all are over 3.
all the valves I have measured are far nearer the data sheet figure than the Taylor figures,
having studied the diagrams i cant see the type of rectifier making much difference as they provide adjustable supplies, I am begining to wonder if the meter has an issue or if theres a shunt I have missed thats a bit high.
maybe its a tolerance issue, 10% here and there will soon add up
if its all the same direction.
Megatron is offline
Old 16th Mar 2019, 8:35 pm   #8
Freya
Freya's Avatar
If it has silicon rectifiers in place of the metal oxide originals then it will be high on its GM readings, the recommended replacement was the GEX34 diode.
Are the original rectifiers still present, if so you could reinstate them, I have never known them to fail.
Stephen
Freya is online now
Old 16th Mar 2019, 10:40 pm   #9
Megatron
No they're not there.
I will try adding extra diodes then to increase the volts drop and see what happens.....
is the bridge or single diode likely to have the biggest effect?
Megatron is offline
Old 16th Mar 2019, 11:56 pm   #10
sven_swe
sven_swe's Avatar
I read in this thread that they replaced the selenium rectifiers with 1N4001 with good results.
sven_swe is offline
Old 17th Mar 2019, 12:19 am   #11
Megatron
I am pretty sure that's what's in there.
Don't the DC supplies just provide bucking voltage for zeroing the meter movement? So I wouldn't have thought they were that critical.
Megatron is offline
Old 20th Mar 2019, 8:55 pm   #12
Megatron
Right then, I have rummaged through my huge tub of bridge rectifiers and diodes, in the bottom I found a GEC bag. In the bag are a large number of CV7176 CV7123 and GEX541.
these all have a low Vf and would all appear to be 6A germainum rectifier studs.
also i have some Erie 1200 028 50V 6735 that also seem to be low vf (0.048v) so probably germainum.
do we think this will fix it? they should be plenty big enough
ill take before and after readings on a fairly high GM valve and see.
Megatron is offline
Old 20th Mar 2019, 10:17 pm   #13
Megatron
Measures an EL84 as a golden sample. Gm 12 book says 8
changed all the rectifiers for germanium ones. re measured the golden sample.
Gm 12.5.
going to test the meter next i think, maybe its springs gone weak?
Megatron is offline
Old 20th Mar 2019, 11:23 pm   #14
Megatron
getting somewhere now i think,
if i set the voltage across the cathode resistor to 1v by adjusting the grid voltage, when i press the test button i get for the EL84 a Gm of 8
repeating with the 6v6GT i get 2.5 (book says 2.6)
it must be something to do with the grid voltage?
anode and screen voltage are correct(AC)
Grid Potentiometer reads OK end to end. and ac transformer output is OK.
however the grid voltage set point to get the 1 volt across the cathode resistor is about double what you would expect.......
Megatron is offline
