Old 1st Feb 2019, 8:28 am   #1
anikimtiaz1990
Default Distributed amplifier
Hello..
Does anyone have the document named " distributed amplification" by ginzton and hewlett.? I dont have access on ieee group...and is unable to find any pdf.
Also can you guys suggest some good books on vacuum tube distributed amplifier desing...?
Thank you....
anikimtiaz1990 is offline
Old 1st Feb 2019, 10:30 am   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Distributed amplifier
I have found it on the internet some time ago when looking for it, so it may still be out there. Noe was also one of the authors.
I had a paper copy at work which a librarian obtained from the British Library, so I didn't bother keeping an electronic copy when I found it on the internet. That paper copy, my desk, and the whole HP building are all long-gone, I'm afraid.
Radio Wrangler is online now
Old 4th Feb 2019, 9:25 pm   #3
G0HZU_JMR
I have IEEE access at my PC at work so I had a go at downloading your doc.
However, it is 2.5Mb in size so it (just) exceeds the forum limits for a pdf file.
I've attached an image of the first page below. Is this the correct document?
If so I'll try and find a way to send it to you.
Regards, Jeremy G0HZU
G0HZU_JMR is offline
Old 5th Feb 2019, 3:28 am   #4
Terry_VK5TM
Terry_VK5TM's Avatar
Try zipping it (as in .zip file) and see if it comes in under the 1.91Mb limit, then it can be posted here.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 5th Feb 2019, 7:17 am   #5
n_r_muir
n_r_muir's Avatar
Good practical examples of valve based distributed amplifier designs are used in the vertical amplifier stages of the Tektronix 545A and the 548A Oscilloscopes of the late 1950/ early 1960's. As far as I remember there is a good description of these in the Tektronix instruction/service manuals which can be downloaded from the BAMA website.
Ross
n_r_muir is offline
Old 5th Feb 2019, 7:21 am   #6
Radio Wrangler
That is the right paper, Jeremy.
It is the seminal paper on distributed amplifiers. I had a copy in my files for decades.
All the design equations you need, and some interesting stuff on tapered lines.
Old 5th Feb 2019, 11:07 pm   #7
G0HZU_JMR
Thanks, David.
It sounds like you might be interested in a copy too! Therefore, I've tried to upload it here:
https://www.qsl.net/g/g0hzu//RF%20Tr...F/01697772.pdf
Let me know if the link works for you.
I tried zipping the pdf file but it didn't reduce in size much. It was still too big... Hopefully, the link above will work.
Old 6th Feb 2019, 12:46 am   #8
Radio Wrangler
Thanks, Jeremy, that's a good clean copy. I think I may still have a copy of a copy somewhere, and it's complete with the references etc.
It's a really important paper. It set out the whole business, and lives on in the wideband integrated distributed amps going up into the millimetre bands.
Cheers,
Old 6th Feb 2019, 10:37 am   #9
GMB
GMB's Avatar
If you want to see an example of a really powerful one, look at this:
http://air-ministry.uk/Model122amplifier.pdf
GMB is offline
Old 6th Feb 2019, 7:44 pm   #10
m0cemdave
Chapter 10 of the book "Radio Transmitters" by V.O. Stokes is a full write-up on the design of the high power types. Worth a read if you can find it.
The 1kW amplifier panels (using 4CX250B's) occasionally turn up at radio rallies. I've seen at least two, over the years, at Stockwood Park. I don't know if anybody has got one going.
It seems there was a 40kW version too...
m0cemdave is offline
Old 6th Feb 2019, 8:29 pm   #11
G6Tanuki
G6Tanuki's Avatar
They were used in cable-TV 'launch amplifiers' - the circuit of the type designed by EMI and used in the Abingdon cable-TV project is here:
http://www.aeolian-hall.myzen.co.uk/circuit.gif
http://www.aeolian-hall.myzen.co.uk/fig28a.gif
[Complete description of Abingdon cable-TV is here: http://www.aeolian-hall.myzen.co.uk/mva.htm ]
G6Tanuki is offline
Old 6th Feb 2019, 9:31 pm   #12
turretslug
turretslug's Avatar
Last year at Dunstable Downs someone was offering something rather like that (as I recall), a row of 4CX- style devices. Quite an impressive beast.
turretslug is offline
Old 7th Feb 2019, 8:53 pm   #13
anikimtiaz1990
Hello evryone....
I apologise for the late reply.....i am really sorry......
And i got the paper......thank you all for your help and kind suggestion.your opinion is very valuable to me....as where i live no one knows anything about vacuum tube technology....i have nowhere to go...but got a great place to talk here.....
Old 7th Feb 2019, 8:57 pm   #14
anikimtiaz1990
I am just wondering. ..that can i make the range to more low frequency? ...like from 10 hz to 1 mhz...? I am new to tube electronics....so trying to keep the power as low as 50 watt per se....as some of you people suggested me earlier.....can i cover this range as i mentioned previously with this technique....?
And thank you all again.....
