30th Jul 2020, 6:15 am | #1 |
Sony HMP 70 problem
So I bought a Sony HMP 70. It kind of works.
However the disc runs a bit low, make a small sound and the return mechanism doesn’t function. I’m aware about the thrust washer problem. I don’t know though what material and the size of the washer to use. Or how to put it there. Do I have to losen the turntable an put it upside down? And then what? Could someone help out a newbie please? |
30th Jul 2020, 1:31 pm | #2 |
Re: Sony HMP 70 problem
Hi and welcome. There was a post in 2017 on this model, from Mr dimples, if you do a search you should find it.
John |
30th Jul 2020, 6:40 pm | #3 |
Thank you for your answer.
However I’ve already read it and I still don’t understand how I’ll manage to put on a washer. I have also looked at old manuals. Maybe I have to remove the turnable and put it upside down to take off the spindle? Well that’s why I have to ask |
30th Jul 2020, 8:27 pm | #4 |
Hi Krisann. Have a look at this :- https://audiokarma.org/forums/index....ny-hmp.754033/
If you click on the pictures you can make them bigger in a new window. Hope this helps. David. |
31st Jul 2020, 1:07 pm | #5 |
Thank you for the link.
I’ll look under the white cog at once, seems to be a lot easier than open up the turnable underneath. |
31st Jul 2020, 1:58 pm | #6 |
Well, I got distracted there a minute from putting a thrust washer on the spindle...
The good news is that I just received a nylon washer. I feel I don’t have the skills to open up the turnable...so I did a cut on the washer and pressed it on the spindle...and now it works perfect; no strange sounds and it rejects automatically. |
