Old 3rd Dec 2006, 11:57 am   #1
Radio_Dave
Radio_Dave's Avatar
Default Help needed with low voltage PSU
I have all the parts to make a little, LM317 based, variable power supply to use when I'm working with transistor radios.
There's plenty of circuits on the internet but the only thing I'm missing is a transformer big enough to give me the minimum output of 18V that I need.
I have got two identical 12V 1.67A transformers but I'm not sure what's the best way to combine them to give me the highest voltage and power .
Should I, simply, connect both secondaries in series, then rectify or rectify each transformer first
Thanks
Radio_Dave is offline
Old 3rd Dec 2006, 12:04 pm   #2
ppppenguin
ppppenguin's Avatar
Default Re: Help needed with low voltage PSU
Connect the secondaries in series. Remember that if you want a low output voltage at a high current the regulator will get very hot. Might be worth having 2 ranges, one with both secondaries in series, the other with just one of them.
ppppenguin is offline
Old 3rd Dec 2006, 1:01 pm   #3
Paul Stenning
Administrator
Paul Stenning's Avatar
Then measure the total voltage with a meter. If they are connected with the wrong phasing the two voltages will be subtracted, resulting in close to zero. If this happens, reverse the polarity of one of them.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now
Old 3rd Dec 2006, 2:38 pm   #4
Radio_Dave
Radio_Dave's Avatar
Thanks guys, I'll do exactly as you suggest, including a single 12V ac input for low voltages
Old 3rd Dec 2006, 6:55 pm   #5
6AL5W-Martin
I want to give you another suggestion.
Get the following Chip:
LM 4975 And as Transformer any 24 upt to 30V / 3-4Amps.
This Chip is a 5A SMPS Regulator, it will use the "restvoltage" as additional useful power for your radio, not as a heating. The maximum rating is 5Amp.
Example: when output = 12V, Input = 24V, load = 5A, Input will only load 2.5A from transformer.
That`s SMPS. There is only one toroid coil to put, very easy !
You will have Enjoy with this, sure
Martin
6AL5W-Martin is offline
Old 3rd Dec 2006, 7:29 pm   #6
evingar
evingar's Avatar
I'm not familiar with that particular device
...but there are a selection of simple to use one chip switching regulators available from National Semiconductor, complete with application circuits. There is a handy selection tool here, it will even design the circuit for you in some instances :-
http://www.national.com/appinfo/power/
I'm sure some of the devices can be bought from RS or Farnell.
One problem may be interference, but the use of ferrite's on the I/O leads and the use of an earthed metal box will probably get around this
Chris
evingar is offline
Old 3rd Dec 2006, 7:57 pm   #7
6AL5W-Martin
excuse a Mistake, i means L4975 ( by ST Micro, also fine = L298 )
i will post apllication. This is L298, pimped with a transistor to output more then 10 Amps
http://www.budoclub-biedenkopf.de/51j4/l298.jpg
to make it adjustable put a pot there where is the both resistors in end. The minimum output voltage is 5.1V As inductivity use a ferrite ring from defect PC Power supply, 1" or like that, and make 25 turns (thick for 10A). thats all, the rest is R C
