Old 17th Jul 2020, 9:37 am   #1
newlite4
newlite4's Avatar
Default Retro Signal Tracer
I had been wanting to make my own signal tracer for some time to go alongside my Heathkit IT-12 and Taylor model 22. The opportunity arose when I picked up a non functioning Tesco Retro DAB radio for a few pounds at the car boot three weeks ago. This would form the basis for an early sixties style instrument which would complement my existing signal tracers.
The chassis is angled within the shallow case to allow more top surface area and to assist cooling. The internals of the plastic case were carved away accurately to allow easy installation of the chassis.
The circuit is fairly straightforward using an ECC83 as signal pre-ampifier and EM84 magic eye driver and an EL84 as a simple audio amplifier. AF and RF inputs are via separate sockets to avoid using a changeover switch. One of the two speakers was retained for use, the other was removed to allow the fitting of the mains transformer.
In use the EM84 gives a bright easy to view display and the audio output from the 4 ohm/5 watt speaker is more than adequate.
By its nature the instrument is quite compact and is easy to store on a shelf where it looks rather like another early sixties valve radio.
Neil
ID:	211172   Click image for larger version
ID:	211173   Click image for larger version
ID:	211174   Click image for larger version
newlite4 is offline
Old 17th Jul 2020, 9:53 am   #2
linescan87
linescan87's Avatar
Default Re: Retro Signal Tracer
Now that's one upcycling project that was well worth the effort, lovely stuff Neil.
All the best, John Joe
www.youtube.com/c/ojnojirishvintagetvandradio
linescan87 is offline
Old 17th Jul 2020, 10:07 am   #3
newlite4
newlite4's Avatar
Thanks John, yes I feel it was a project well worth doing. There are many retro inspired consumer goods at the car boots these days many of which no longer work so the raw materials are readily available to make original looking valve based test gear and radios.
Neil
newlite4 is offline
Old 17th Jul 2020, 2:03 pm   #4
The General
The General's Avatar
Very nice job Neil, I like it. Compact, useful & bench sized. I can't think of a better way to up cycle a DAB radio. That'll learn it!
Mark
The General is offline
Old 17th Jul 2020, 2:47 pm   #5
ValvoStef
ValvoStef's Avatar
Smashing project with an excellent result. I love it.
Failing to prepare is preparing to fail ...
ValvoStef is offline
Old 17th Jul 2020, 3:15 pm   #6
Superscope
Excellent Job,
As has been said, a great upcycling Job, and a better use than the original one.
I couldn't help notice the Bambinetta Radio in the Photo.
I inherrited the exact same Radio (In Red, but now Pink).
I remember my Mother listening to the Archers every week on it.
Must get round to seeing if it still works.
Ian
Superscope is offline
Old 17th Jul 2020, 5:47 pm   #7
newlite4
newlite4's Avatar
Yes, unusually it looks as though the Tesco DAB was modelled on the Bambinetta. Bambinettas are quite nice little radios but the outer shell case tends to split after some years and they are a bit squeeky having a very simple circuit design.
Yes, get that DAB nonsense out of that nice case and build something sensible into it , I couldn't agree more.
Neil
newlite4 is offline
Old 22nd Jul 2020, 5:45 pm   #8
qualityten
Great job! I am equally impressed that you found a car boot to go to. It's pretty quiet on that front up in the NW, as far as I know.
qualityten is offline
Old 24th Jul 2020, 6:42 pm   #9
eddie_ce
eddie_ce's Avatar
Hi Neil,
an interesting little project which I would like to copy. Can you confirm that the value of the resistors on the anodes of the ECC83, pins 6 and 1 are 15k and 10k respectively? The drawing is a little unclear.
Many thanks
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 26th Jul 2020, 4:14 pm   #10
newlite4
newlite4's Avatar
Sorry for the late reply, just dipped back in to this post. ECC83 pin 6 is 150K and pin 1 is 10K. The car boots around here started last month, but bad weather has left them a little patchy.
Neil
newlite4 is offline
Old 26th Jul 2020, 4:25 pm   #11
eddie_ce
eddie_ce's Avatar
Thank you Neil
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
