Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#21 |
Cut a bit off the old control shaft and joint it with a bit of tube, plastic or metal, even bend up a bit of a baked bean can, then add a bit of suitable glue and you have an extended shaft.
#22 |
Hi vidjoman,
Many thanks for you message and tips, in the same train of thoughts, I could possibly use two lots of heatshrink. If I can't find a coupler, I may well do as you suggest. Many thanks once again, all my kindest regards, Ted. |
#23 |
Before you heatshrink it use araldite or similar epoxy as a filler and then shrink it - it'll make it stronger.
#24 |
Hi vidjoman,
Many thanks for your kind help, that's a good idea and I was also thinking of cutting a slot in each shaft and fitting in a piece of metal in to act as a key for added strength. Many thanks once again for your very kind help. All my kindest regards, Ted. |
#25 |
There are some shaft extensions kits listed on e bay sorry I don't know how to post links .
With regard to the cartridge you are correct in saying it should have a medium output fitted. |
#26 |
Good morning Ted,
I was looking for something else yesterday and saw this. It is 1meg log as you need. The body is 1 1/4” diameter, 3 1/4” overall and from the top of the lugs on the body to the end of the spindle is 2”. If this is any use, pm me your address and I will pop it off to you free of charge. Kind regards, David |
#27 |
Hi Leslie 5555,
Many thanks for your message and much appreciated kind help, I have managed to find some couplers and ordered five, and many thanks for the info on the cartridge. Hi David, Many thanks for your very kind help and offer, I have managed to find a replacement pot now, so all should be ok. but I just can't thank you enough for your very kind offer, you are a true gentleman. Many, many thanks to you both, all my very best and kindest regards, Ted. |
#28 |
Good morning Ted,
