21st Oct 2021, 10:44 pm | #1 |
Are Ceramic Tools Essential?
How essential is it to use non-magnetic screwdrivers and sockets when working on tape machines? I suppose an alternative would be to use a mains-powered demag machine once you've finished working? Ceramic tools aren't only expensive, but I'm nervous that they aren't going to be as tough as their steel equivalents. On top of that, as tape machines are a hobby to me (I work in electronics and have plenty of test kit, but it's for actual work, not fun) I can't really jusitfy spending hundreds of quid on tools I might use once or twice a year. I have test tapes and alignment gauge, along with scopes and FFT machines etc. My main interest at the moment is getting my cassette machines 100% so that I can transcribe precious tapes. I find that each machine will play certain tapes well, but not others. It seems that you need a variety of machines that are tip-top if you want to transcribe a collection decently. I also have a 1/4" reel machine, but that is on the back-burner. It would be lovely to find time to get that up to scratch as well... TIA |
22nd Oct 2021, 12:01 am | #2 |
Re: Are Ceramic Tools Essential?
You don't want to wave magnetised tools around a tape transport, obviously, but ordinary steel, degaussed, is perfectly adequate. A degausser is much cheaper than fancy materials, anyway. Trouble is, so many screwdrivers seem to be magnetised intentionally these days.
22nd Oct 2021, 2:06 am | #3 |
I've had an old tape bulk eraser in my shop for a long time. If I'm in any doubt about a screwdriver or other tool before using it near a tape path I can degauss it in 5 seconds. It's be a very useful tool especially since it's always plugged into the mains and is activated by a push and hold switch, so it cant be accidentally left on to burn itself. I keep it on the other side of the room, well away from recorded tapes.
Not sure what you mean by needing a variety of cassette machines to optimise playback on a variety of cassette tapes. |
22nd Oct 2021, 2:37 am | #4 |
Ceramic scissors used to be sold for editing magnetic tape.
If you are worried use a simple demagnetising wand after working on a machine. The bias oscillator does a pretty good job if record is left engaged for a few minutes with or without a tape in the machine. |
22nd Oct 2021, 9:08 am | #5 |
We never used special non magnetic tools when I was at Leevers Rich and I have never knowingly seen them in use anywhere else, including the BBC.
As mentioned above regular demagging of tools that get close to heads is sufficent. |
22nd Oct 2021, 9:34 am | #6 |
Ceramic tools are useful for tuning RF coils without much proximity effect, but that's about all. They are expensive and fragile. Demagnetisers are cheaper and more robust.
22nd Oct 2021, 9:44 am | #7 |
Plastic knitting needles with the point cut off and then filed to a chisel point can be useful
Time flies like an arrow, fruit flies like a banana |
22nd Oct 2021, 12:17 pm | #8 | |
I knew this was the best place to ask such a question! You have all been so helpful, thank you!
The 'Han D Mag' appears to be an industry-standard with pros (I have an old TDK hand-held unit that I bought at Laskys, but I very much doubt it'll have enough puff in it). I will have to ask Santa for the Han D -) Quote:
Thanks |
22nd Oct 2021, 12:50 pm | #9 |
I think you're right about azimuth. I seem to remember most of the tape decks I used to play with as a teenager (70s and 80s cheap stuff, including boom boxes and music centres) had an azimuth screw which you could get at while the tape was running. That was how we used to set it - put a pre-recorded tape in (which hopefully had been recorded on a lined-up machine) and then twiddle for maximum top end.
Later at the BBC I seem to remember a Lindos gizmo (?) with which to measure while twiddling fancy Studer cassette players - but it did the same job! This comes to mind because maybe 20 years ago I dredged this info to the front of my mind to impress a girl who was working in the RTE music library and was going mad with a tape deck (just before internet music, I guess!) and playing her tapes at home on the most out-of-alignment music centre imaginable. Alas, she was not _that_ impressed
"The best dBs, come in 3s" - Woody Brown |
22nd Oct 2021, 6:15 pm | #10 |
The IBM guys who used to service the reel-to-reel tapedrives on our mainframes used tools that looked to be made of Brass.
Their 'alignment' process was basically to put the drive into 'maintenance' mode, load a reference tape they brought with them, attach a little box with a bunch of 7-segment LEDs on the front, then the drive did a 'fast-forward' and they twiddled the azimuth/elevation contols on the drive to get the lowest aggregate reading across the nine data-stripes on the tape. In practice you could never get all-zeros across all nine channels.
22nd Oct 2021, 6:54 pm | #11 |
Designing a cassette deck with a front panel azimuth adjuster could be tricky for the manufacturer because the head moves forward and back and so does the relevant azimuth screw. Often the screw is only accessible when the deck is in play mode so you can't leave a small adjuster screwdriver attached to the screw without doing damage. By contrast, open reel deck heads are stationary, making things simpler. For easy regular adjustment of azimuth it's probably either one of the rare Nakamichi models with the adjuster built in, or some other mod to an existing deck. Even cutting away part of a panel so a small driver can remain permanently attached to the azimuth screw without fouling can be a great help.
I suspect regularly azimuth adjusting is often not done because it's too fiddly. That seemed like a good incentive to work out a way to make adjusting easier, at least having many cassettes to transfer. Making adjusting easier, and avoiding the expense, was the incentive I needed to make some mods myself. Ugly mod? Probably, but for me it's a tool, a means to an end, not an object of worship. Last edited by TIMTAPE; 22nd Oct 2021 at 7:23 pm. |
22nd Oct 2021, 7:35 pm | #12 |
Just to add, this also avoids accidentally magnetising the head via one of those confounded magnetised screwdrivers.
23rd Oct 2021, 12:57 am | #13 |
We can always confuse everyone by having a flip over head auto reverse deck.
There is two screws. There is one for each direction and very little ferrous metal to worry about. There are two twiddling holes in the cassette cover for twiddlers to get at |
23rd Oct 2021, 1:09 am | #14 | |
23rd Oct 2021, 2:56 am | #15 |
I agree James. For transferring a lot of cassettes though, adjusting the factory azimuth screw especially multiple times can lead to problems. Most tape players were never designed for regular adjusting of that tiny unlubricated screw, and on a deck with a worn (grooved) tape head, adjusting azimuth can crease the tape or worse. It certainly requires care.
23rd Oct 2021, 9:52 am | #16 |
Thanks.
I have a couple of full-track azimuth adjust tapes. My feeling has always been that unless the machine has PB azimuth as a design feature, I am risking curling the tape (as well as loosening the screw / nut over time, which is a concern, considering the carriage moves up / down quite a lot). My tapes are important to me, but I am concerned about getting a Nak, as we're at the top of the market for such things, and it's very easy to get straddled with a dog (you don't see heads under the microscope in the sales photos!). The plastic wheels that adjust the head make me nervous as well - after 30-40 years, how tough will they be? My Technics has a specially-designed Record azimuth screw, but the PB one isn't easily accessed. I also note that the screws used to retain head on many decks have quite coarse threads... I would've thought you'd want a very find pitch one. It does seem to me that it could be quite easy to skew the tape if being clumsy. It also seems to me that the Nak systems (particularly elaborate automatic ones) have plenty of scope for maintenance issues after 30-odd years, mechanically and electronics-wise. edit: and another thing: the only Nak with Quartz lock is the Dragon. The main tech for Naks in Europe now refuses to take on Dragons, as he says 9/10 have worn heads. Although non-QL machines can give excellent W+F, QL gives peace of mind in terms of hearing at the right pitch. All my Sony machines have QL. And they also have other innovations that Nak never did. One magazine showed the Sony 666 to have lower modulation noise than the Nak 505. |
24th Oct 2021, 3:05 am | #17 | |||||||||
Knowing this, I'd never buy a Dragon for the auto azimuth feature which actually has its limitations even if working at its best. Richard Hess says it is very slow to react, and only works if the right track from which it gets its information carries a good, strong signal. Not good for archival tapes in all sorts of condition. Having said that, cassette heads can be relapped, including the special Dragon repro head. I wonder if the fellow in Europe relaps them. Nak classic heads are actually easier to relap than most other cassette heads because they have no attached guide in the way. All my Nak record or play heads I've relapped, some more than once. For me one of the much more affordable dual capstan Naks is a more realistic purchase for high quality transfers. Of course they need to be in good working condition. See photo of a mod I made to another Nak 480. The plastic azimuth adjuster already has a hole moulded in its centre. I found a piece of wire which fitted snugly in the hole and allowed me to make the front panel adjuster without much effort. A piece of wire, a small plastic knob and some careful filing of a few deck parts to allow clearance. The exposed adjuster is vulnerable though. I should fit a shroud around it to protect it from accidental knocks. Note too another unusual Nak feature: the white wheel to the left allows easy head height adjustment. Not needed as often as azimuth but good to have. I made a felt pen mark on the screw at the 12 o'clock position to indicate standard height. Last edited by TIMTAPE; 24th Oct 2021 at 3:18 am. |
24th Oct 2021, 11:33 am | #18 |
Thank you, Tim - very thought provoking.
It's looking to me that, for serious archiving jobs, either I will have to modify a machine as you have done, or find a good CR-7. I really like the Sony ES machines and have 2 of them, with another coming from Japan. However, as you say, getting access to the azimuth screw requires the removal of various parts (shield for one) that are designed to be in-place during playback. I'd have to take door off (v. easy), but then remove screws for shield (easy to lose...), adjust *for that particular tape*, and then screw back on... Bit of a PITA. |
24th Oct 2021, 1:52 pm | #19 |
I guess I've just gotten used to the convenience front panel adjuster now. Adjusting the head azimuth with a small driver should be OK so long as it's done carefully. Many people seem to do it this way.
29th Oct 2021, 9:09 pm | #20 |
Ok, I’ll ask the dumb question. How do you demag a screwdriver with a bulk eraser? Do you just lay it on top for a few seconds or do you have to slowly draw it away?
Small Scotch, New Aids and Happy Ears |
