7th Jul 2018, 1:07 am | #21 |
Re: Capacitors
Hi Dorian, I've just looked on Ebay and various people are selling both 470uF 25v and 10uF 63v axial capacitors though you may have to buy a pack of five. If you are wanting genuine vintage capacitors from the 1960s or 70s these may be a little more difficult to obtain. Hope this helps.
Regards Martin
Regards Martin |
7th Jul 2018, 6:59 am | #22 |
Re: Capacitors
Perennial question. The answer is, use caps with voltage and capacitance ratings the same as,
or slightly higher than the originals. They will work perfectly.
7th Jul 2018, 7:31 am | #23 |
Re: Capacitors
http://cpc.farnell.com or https://www.rapidonline.com do electrolytic caps as well as other components.
Andy.
7th Jul 2018, 7:59 am | #24 |
Re: Dansette Prince
Morning Dorian
I see you have received your answer ( CPC/Farnel and Rapid) I also use these two suppliers and occasionally Crickelwood Electronics and RS. Cheers John |
7th Jul 2018, 8:57 am | #25 |
Re: Dansette Prince
As a footnote to the above, 400uf caps. are , AFAIK, no longer made. 470uf is the nearest available 'preferred value' . As to working voltage, any cap. of the nearest available value, having a working voltage equal to, or greater than, that of the original, can usually be substituted for faulty ones of values & voltages no longer made. 63v.Electrolytics should be stocked by most suppliers, and, in most cases, can safely be used to replace 64v. types. Speaking of suppliers, another good one is Rapid Electronics.
7th Jul 2018, 2:08 pm | #26 | |
Re: Capacitors
7th Jul 2018, 2:23 pm | #27 |
Re: Dansette Prince
Thanks to you all for all your help with this
11th Jul 2018, 5:31 pm | #28 |
Re: Dansette Prince
This might be helpfull to know that the sound problem has been solved it was a resistor R6 47.0 ohm 4% and R6 on the circuit diagram ok thank to all who helped
11th Jul 2018, 7:42 pm | #29 |
Re: Dansette Prince
Sorry did not last more than an hour so not that after all
