1st Jul 2018, 9:57 pm | #1 |
Philips turntable in a hurry
I never noticed it before,but while checking the speed I measured that my Philips 22CG008/00 turntable plays the 33 1/3 rpm records in exactly 59 seconds.(45 rpm is spot on).
But this model has no speed adjustment. Is this a problem a decent listener will hear or is the deviation too small? Jard N. |
1st Jul 2018, 10:24 pm | #2 |
Re: Philips turntable in a hurry
A very nice turntable from the golden age of Philips Hi Fi. The speed is well within tolerance....relax and just enjoy the music!
Edward. |
2nd Jul 2018, 9:17 pm | #3 |
Thank you Edward for your response.
I´m not a very critical listener. Once I inherited a box with classical L.P.´s and on a cold winter afternoon I played a lot of them:Bach, Beethoven,Mozart etc. Not too bad although it was not my real taste. But around dinner-time I saw to my big shame they were all played at 45 rpm instead 33 1/3. Jard N. |
3rd Jul 2018, 12:04 am | #4 |
Wot? Am I mis-reading this? I don't have any 33rpm records that would play in 59secs at 78rpm! How can that be 'well within tolerance'?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
3rd Jul 2018, 12:18 am | #5 |
I don't really understand the test result!!
A 33rpm record can run up to 30 minutes per side. So how can a 33rpm record last for less than a minute? Have Philips invented a Warp Speed deck? |
3rd Jul 2018, 12:45 am | #6 |
I took it to mean the turntable does 33 1/3 revolutions in 59 seconds where it should be per minute.
David. |
3rd Jul 2018, 7:33 am | #7 |
Yes David I read it the same way, it is one second slow.
Cheers John |
3rd Jul 2018, 7:36 am | #8 |
One second fast?
3rd Jul 2018, 7:47 am | #9 |
Ops it is early, or that is my excuse, yes David you are of course correct.
Cheers John |
3rd Jul 2018, 7:48 am | #10 |
Even Graham.
Cheers John |
3rd Jul 2018, 8:11 am | #11 |
33.33.. revolutions in 59 seconds equates to 33.89 revolutions in 60. This is about 1.7% fast.
I think someone blessed (or cursed?) with perfect pitch would notice it, as for the rest of us I doubt it. EDIT I've have just used Audacity to generate a 1000Hz tone and then a 1017Hz tone and I can easily hear the difference but only because I had the original 1kHz tone in my mind for reference. Last edited by ukcol; 3rd Jul 2018 at 8:20 am. |
3rd Jul 2018, 11:39 am | #12 |
3rd Jul 2018, 12:31 pm | #13 |
3rd Jul 2018, 1:38 pm | #14 |
Well now look here - if that speed variation was on a Project Signature 12 turntable, I may have some cause for concern, but if it is on a nice old (45 yrs) Philips budget deck, I would be highly delighted!
Edward. |
4th Jul 2018, 12:03 am | #15 |
Er no, but I see where you've gone wrong.
60/59 = 1.01695 (to 5 decimal places) or 1.017 to 3 decimal places. But we are stating a percentage increase (percentage over speed) and not the ratio of 60 to 59. 60 is 101.7% of 59 or 1.7% greater than 59, (101.7 - 100) You had me worried for a minute. |
4th Jul 2018, 8:52 am | #16 |
Hello Colin,
Oops! Sorry about that. You are, of course, quite right! Regards, Dave. |
4th Jul 2018, 10:14 am | #17 |
1.7% speed difference is about 1/3 of a semitone. As Colin found out by experiment that is easily discernible by doing a comparison one after the other. But only someone with perfect pitch will notice this when listening to music. As has already been said
If an orchestra (or a piano) has tuning errors of 1/3 of a semitone anyone will definitely hear it. https://www.youtube.com/watch?v=hpJ6anurfuw |
4th Jul 2018, 10:27 am | #18 |
the calculation normally starts with the standard.
The correct time should actually be 60 seconds. This is the wanted 100%,but in reality it is 59 seconds thus 1 second wrong. So 1/60 times 100% gives 1.67 off the nominal value Jard N. |
4th Jul 2018, 11:21 am | #19 |
In an orchestra or piano, individual notes or individual instruments are tuned um, individually. One thing alone a third of a semitone off will stick out like a sore thumb.
But with the turntable speed error, everything will shift together and it will be somewhat less noticeable. Someone with good pitch won't like it, but it's trivial to what lots of people keep on listening to. Tolerance varies amazingly. David
4th Jul 2018, 11:52 am | #20 |
Reminds me of when I had to set the speed of a cassette deck. I can't remember what it was I was playing, but it was some kind of pop music rather than classical stuff. It sounded perfectly OK over quite a range of speed settings. I eventually made a test tape on another machine using an audio generator and a frequency counter. I think the correct setting was at one extreme of the acceptable range.
