Reply
Old 25th Sep 2023, 3:51 pm   #1
Smithdoor
Smithdoor's Avatar
Default Dual Trace /Electronic Switch build
Look at building a Electronic Switch for my oscilloscope.
Please comment on the schematic
Dave
Name:	Dual trace 1 of 4 .jpg
ID:	285575   Click image for larger version
Name:	Dual trace 2 of 4 .jpg
ID:	285576   Click image for larger version
Name:	Dual trace 3 of 4.jpg
ID:	285577   Click image for larger version
Name:	Dual trace 4 of 4.jpg
Smithdoor is offline   Reply With Quote
Old 25th Sep 2023, 5:40 pm   #2
Mark1960
Default Re: Dual Trace /Electronic Switch build
I wonder if it might be easier to use more modern components, maybe 74lvc1g3157 for the switching. Input/output voltage range would be limited to 0-5v, so would need to have some kind of input attenuator and protection circuit. These are in surface mount package, but sot-23-6 are not too difficult to hand solder.
Mark1960 is online now   Reply With Quote
Old 25th Sep 2023, 11:36 pm   #3
Smithdoor
Smithdoor's Avatar
It is interesting.
Look at specific sheet.
Protection could be a Zenor diode and fuse.
I would like find it in DIP if goes up in smoke it easy to replace.
Thank you
Dave
Old 26th Sep 2023, 1:02 am   #4
Radio Wrangler
Radio Wrangler's Avatar
Zener diodes aren't much use for protectinf fast signals. They have a surprising amount of junction capacitance, also they conduct like normal diodes in the other direction.
So any protective shunt needs low capacitance fast diodes to do the clamping, with zeners and a bias supply making the voltage level the fast diodes clamp to.
Old 26th Sep 2023, 8:42 pm   #5
Ed_Dinning
Hi Folks, back in the late 60's early 70's Peter Cairns designed several scope circuits that were published in RC, WW, PW and PTV.
These all used common discreet components.
It might be worth a look to see if you can find them, if no luck mail me and I'll see what can be found when I get a minute
Ed
Ed_Dinning is offline   Reply With Quote
Old 27th Sep 2023, 3:30 am   #6
Smithdoor
Smithdoor's Avatar
Here one that looks good
File Type: pdf Electronic Switch Dual trace all transistor.PDF (117.8 KB, 44 views)
Old 27th Sep 2023, 4:48 pm   #7
Smithdoor
Smithdoor's Avatar
Here is my drawing on electronic switch.
Dave
File Type: pdf ELECTRONIC SWITH SEPT 27 2023 Layout1 (1).pdf (21.0 KB, 56 views)
Old 27th Sep 2023, 11:30 pm   #8
Smithdoor
Smithdoor's Avatar
This how to use a Electronic Switch by Heathkit.
Dave
Name:	1 how electronic switch works_edited.jpg
Old 29th Sep 2023, 3:12 am   #9
Smithdoor
Smithdoor's Avatar
Here is a better information on using a Electronic Switch
FYI I used my Eico 488 on my 435 without using SYNC.
If looking for the SYNC it can located on front panel, on back of Oscilloscope or on Horz input and switch to SYNC and may not be labeled but on Switch.
Name:	5) 1 of 4 using dual trace_edited.jpg
ID:	285735   Click image for larger version
Name:	5) 2 of 4 using dual trace_edited.jpg
ID:	285736   Click image for larger version
Name:	5) 4 of 4 using dual trace_edited.jpg
ID:	285737   Click image for larger version
Name:	5) 3 of 4 using dual trace_edited.jpg
Old 29th Sep 2023, 5:26 pm   #10
Smithdoor
Smithdoor's Avatar
Here a different schematic I am looking at.
File Type: pdf Electronic Switch Dual trace all transistor.PDF (117.8 KB, 19 views)
Old 4th Oct 2023, 1:55 pm   #11
Smithdoor
Smithdoor's Avatar
Here latest schematic on a simple electronic switch.
Old 6th Oct 2023, 8:44 pm   #12
Smithdoor
Smithdoor's Avatar
Latest update
Old 7th Oct 2023, 4:16 pm   #13
Smithdoor
Smithdoor's Avatar
This is all transistor electronic switch.
Please comments
Dave
Old 10th Oct 2023, 12:33 am   #14
Smithdoor
Smithdoor's Avatar
Update getting closer to finishing.
Name:	electronic switch .jpg
Old 10th Oct 2023, 7:33 am   #15
Craig Sawyers
Craig Sawyers's Avatar
I'd copy a circuit from eg the Tektronix 453. All discrete, with ch1/ch2/chop/alt/add switching too. 50MHz bandwidth.
But your options are going to be of very limited bandwidth with simple potentiometers as input attenuators. Switched attenuators with careful compensation are essential if you want a bandwidth more that a few hundred kHz.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 10th Oct 2023, 2:10 pm   #16
Smithdoor
Smithdoor's Avatar
Thank you for your input.
I would worry about 50 MHz but most oscilloscopes that need a Electronic Switch is only rated for 5 MHZ.
The cellphones using the mic plug is only rated for 40KHZ.
The components are rate for 250Mhz
Dave
Craig
Old 10th Oct 2023, 2:27 pm   #17
Smithdoor
Smithdoor's Avatar
Here spec I am looking.
Trying to do better that the 1960's.
Dave
Craig
Old 10th Oct 2023, 6:42 pm   #18
Smithdoor
Smithdoor's Avatar
Here is a updated schematic.
Craig
Old 12th Oct 2023, 6:54 pm   #19
Smithdoor
Smithdoor's Avatar
Here update close to end.
Old 13th Oct 2023, 4:28 pm   #20
Smithdoor
Smithdoor's Avatar
This includes parts ID and protection resistors
File Type: pdf 1) ELECTRONIC SWITCH OCT 2023 Layout1 (2) (1).pdf (21.5 KB, 19 views)
Reply
