Old 18th Jul 2023, 2:39 pm   #1
ChrisPurchase
Location: Hatfield Hertfordshire & St Leonard's-on-Sea, UK.
Default Smiths Sectric 12" - weak motor
My Sectric has lain unused for maybe 15 years and its rotor has almost fully demagnetized. Has anyone had success remagnetising pls?
ChrisPurchase is offline
Old 18th Jul 2023, 3:40 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Smiths Sectric 12" - weak motor
Hello and welcome.
Could you post some pictures, please? The "Sectric" branding was used from the 1930s right through to the 1970s.
Nick.
Nickthedentist is offline
Old 20th Jul 2023, 11:26 am   #3
ChrisPurchase
A few pix. Any advice on weak motor gratefully received - I'm loathe to replace the entire mechanism
ID:	281654Click image for larger version
ID:	281655Click image for larger version
ID:	281656Click image for larger version
ID:	281657Click image for larger version
Old 20th Jul 2023, 8:57 pm   #4
Robsradio
That is the Bijou movement, which is usually reliable. It may just need a service and lube, I would try that first, please don’t ‘quartz’ it!
Robsradio is offline
Old 21st Jul 2023, 12:22 pm   #5
ChrisPurchase
Sadly no. With the motor removed, apply power and it doesn’t start. Given it a helping twiddle and it spins, but barely enough torque to keep turning. I conclude the rotor needs remagnetising, but how best to do?
Old 21st Jul 2023, 2:13 pm   #6
ChrisPurchase
With the motor removed from the gear train, the rotor can be spun freely by hand. There is virtually no mechanical resistance as the rotor poles pass the stator shields. Unsurprisingly therefore, when power is applied, the motor won't start. Apply a hand twiddle and it keeps turning, but with barely enough torque to sustain rotation
