Old 28th Apr 2019, 7:02 pm   #1
Sinewave
Sinewave's Avatar
Default Taylor 65A All Wave Signal Generator
So today at the rally in Andover I picked this up.
I don't need another sig gen, but I just couldn't resist. I love the look of it, so I had to have it.
My photos show no screws on the front panel, because I removed them to show the inside.
There's a mains cable attached, no plug on it. Some excuse was given as to why there's no plug on it with some certainty given that it works.
I'm thinking of a variac start...
ID:	182056   Click image for larger version
Name:	Taylor 65A(2).jpg
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 1st May 2019, 2:31 pm   #2
avocollector
Default Re: Taylor 65A All Wave Signal Generator
oooh luverly - much envy as I've really run out of room for any more goodies. Building a new extra shed of course but that will only house the overflow decently (and give me back the garage). Wonder what inspires one to want 'just one more' when you already have 20 or 30?? LOL - great fun though.
avocollector is offline
Old 1st May 2019, 6:14 pm   #3
Sinewave
Sinewave's Avatar
This inspired me due to it's appearance and being told that it's from the 30s and working. I've still yet to test it though.
This is probably my 5th signal generator. Some of the others compliment each other by covering ranges the others don't.
Sinewave is offline
Old 1st May 2019, 6:40 pm   #4
HamishBoxer
HamishBoxer's Avatar
Every body should own this model, had mine years.
Do not trust the blue /yellow replacement cap though, they used to fail years ago on b/white TV's.
HamishBoxer is offline
Old 1st May 2019, 7:13 pm   #5
Sinewave
Sinewave's Avatar
So what do you think, soft start or test the cap first?
Sinewave is offline
Old 1st May 2019, 7:19 pm   #6
Sideband
Sideband's Avatar
If it's across the mains...chop it out......unless you like smoke and bits of tinfoil floating about the workshop!
Sideband is offline
Old 1st May 2019, 7:28 pm   #7
Sinewave
Sinewave's Avatar
I'll ask the wife to switch it on then whilst I pop out...
Sinewave is offline
Old 2nd May 2019, 12:39 pm   #8
avocollector
Just out of curiosity how many have actually had a cap explode on them?? happened to me once and surprisingly while I was using an electric hedge trimmer, but never on vintage radio or test gear to date and yes I happily plugged in and switched on many time before present awareness of using a limiter etc.
Old 4th May 2019, 9:14 pm   #9
Sinewave
Sinewave's Avatar
There is some functionality.
I tested it with my scope, but had to improvise as I don't have a bnc to one of those regular coaxial (tristar?) plugs.
I did get a nice enough sinewave with readings being sensible. It dropped out every now and then, but that my have been my connection. So I'll need to get an adaptor and have more of a play!
I'll leave it for now as I've had a few but was just curious.
Sinewave is offline
Old 8th May 2019, 7:31 pm   #10
ekjdm14
That's interesting, I have a 65c which is largely similar aside from the orientation of the rectifier which is longitudinal on mine, and the fact that mine has a BNC connector (although believe it's a mod.) that would appear to be from 1950.
Not sure when they were introduced though I'd suggest the date stamp on your transformer would be more likely '51 than '31 especially given the Octal valves which I believe were introduced around 1935-ish. But I agree they're a handsome looking piece of equipment and useful too, Have you done any more testing with yours yet? I'm still waiting on one 6J5 valve before I can bring mine up & see what's cooking...
ekjdm14 is offline
Old 9th May 2019, 8:57 am   #11
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
I have a 65B which I picked up in Ambleside in the Lakes whilst staying with my daughter in Manchester - an eBay jobby.
Interesting to see the detail differences in the front panel.
My dial bezel is chromed.
It's on the roundtuit pile.....
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 9th May 2019, 9:51 am   #12
Sinewave
Sinewave's Avatar
I am wondering if my scale plate is not an original as it has a range which isn't covered by the generator.
Sinewave is offline
Old 9th May 2019, 11:31 am   #13
livewireless123
livewireless123's Avatar
Here is mine, cost me a fiver second hand in the mid sixties. still gets fairly regular use and haven't done any repairs on it for years. I do check its frequency against a trio comms RX. the advert is from a 1949 Wireless World.
The original output connector was a 2 pin job, I put on a standard jack plug.
ID:	182762   Click image for larger version
HAPPINESS IS A WARM WIRELESS
PREVIOUS USER NAME- MIKE G3ZII
livewireless123 is offline
Old 9th May 2019, 12:24 pm   #14
avocollector
All sinewave's fault - after seeing his Taylor I could not resist this Monarch 12 - valves are 76, 31, and 84.
Oh and of course not a chance in a million it works but that's part of the fun.
Name:	Monarch model 12.jpg
Old 9th May 2019, 12:36 pm   #15
Sinewave
Sinewave's Avatar
I think you're right, this is a 50s set, not a 30s set.
No further testing yet. I'm not sure whether to use an adaptor or just change the socket to a BNC.
Sinewave is offline
Old 9th May 2019, 3:50 pm   #16
ekjdm14
If the Belling Lee(?) connector is in good condition I'd probably leave that in place, the BNC on mine will be useful as I have some BNC-to-crocodile leads lying around that will be good to use with it but if it had the standard co-ax plug I can see no reason to get shot of it for the kind of use it's likely to see. Obviously in a pro/field environment BNC would be more reliable but for home/hobby use I'd say it's fine as it was.
ekjdm14 is offline
Old 9th May 2019, 5:06 pm   #17
Sinewave
Sinewave's Avatar
I may just get an adaptor so that I can use my BNC leads with it, they're less than a £1 for an adaptor.
Sinewave is offline
Old 28th May 2019, 10:26 pm   #18
Sinewave
Sinewave's Avatar
I bought the regular socket to BNC adaptor which has made this much easier to test. The 65A all seems to be a solid performer.
Also at the NVCF in Warwickshire, I saw the B version and couldn't resist. All works fine but the internal modulation is a bit noisy and some of the knobs are a bit stiff.
Sinewave is offline
Old 3rd Jun 2019, 12:53 pm   #19
ekjdm14
Inspired by this thread, I shall attempt to find time today for testing my 65C. So far I've brought it up on variac and voltages seemed sensible etc but I didn't seem to get anything out of it. May have a poke around today, get a 'scope on it & hit it with a mains switch-on, maybe I just brought it up too slowly!
ekjdm14 is offline
Old 3rd Jun 2019, 1:07 pm   #20
Andrewausfa
Andrewausfa's Avatar
Someone might have stuck high voltage up the attenuator or it could be dirty switches. Or, in fact, any number of reasons!
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
