Old 3rd Oct 2019, 11:16 am   #21
vidjoman
Default Re: Weird circuit in Fidelity record player.
Often the sellers of items don't have an engineer's knowledge of these matters. If it has two transformers then they think it's a full mains transformer, but it's not always so.
Descriptions are often wrong on auction sites.
vidjoman is online now
Old 3rd Oct 2019, 11:18 am   #22
vampyretim
Originally Posted by John10b View Post
Further to Nickthedentist post #3, and the link he provided, the seller states the following “The amplifier has a proper mains ransformer (sic) which allows for an isolated, earthed chassis “.
John
The one that I'm working on definitely doesn't have a mains transformer but it does have two transformers which at first led me to believe that it did have a mains transformer.
vampyretim is offline
Old 3rd Oct 2019, 11:28 am   #23
John10b
I completely agree, any chance of a picture ?
John
John10b is offline
Old 3rd Oct 2019, 2:02 pm   #24
vampyretim
John
Hi John,
I'm away from Bristol for a week but will upload some pictures of the amp when I get back.
Many thanks.
Old 3rd Oct 2019, 2:12 pm   #25
John10b
Ok ta, just thought it would be interesting to see amp.
John
John10b is offline
Old 3rd Oct 2019, 4:40 pm   #26
Edward Huggins
Well it does have a Mains transformer now if there are 2 transformers there....
With photos, we can tell if it is for the filaments only or if it is double-wound and therefore offers an isolated chassis.
Edward.
Edward Huggins is online now
Old 3rd Oct 2019, 11:15 pm   #27
Michael Maurice
Michael Maurice's Avatar
Default Re: Weird circuit in fidelity record player.
Originally Posted by Nickthedentist View Post
Someone here claims it's got an isolated chassis: https://www.worthpoint.com/worthoped...tro-1694440334
I do hope it was an isolated chassis, otherwise God help the buyer.
Originally Posted by vidjoman View Post
Often the sellers of items don't have an engineers knowledge of these matters. If it has 2 transformers then they think it's a full mains transformer but it's not always so. Descriptions are often wrong on that auction site.
How can you tell from a picture Edward? If the transformer acts as an autotransformer with just the heaters isolated, then at first glance you'd never know.
Especially if its like the circuit described in post #10
Originally Posted by Herald1360 View Post
So did the (cheaper?) tapping on the motor winding approach.
But they weren't available till around 1960, starting with I think the UA12.
Forum Moderator
Michael Maurice is offline
Old 4th Oct 2019, 7:49 am   #28
Edward Huggins
My point in Post #26 is that if it were just a filament transformer (autotransformer) one would expect to see just 4 winding connections, and if isolated, then at least 5.
Edward.
Old 4th Oct 2019, 9:11 am   #29
vidjoman
Should be able to tell from a photo as an isolated type will have 3 windings and heater only just 2. There might be a snag if there are extra tags for a primary tap for 200 and 240 volts but that would be rare in this type of player.
Old 6th Oct 2019, 9:56 am   #30
vampyretim
Hello guys,
I'm away from Bristol for a few days but as far as I can recall the transformer has 4 taps.
Many thanks
Old 6th Oct 2019, 11:35 am   #31
julie_m
It would need to have 5 or 6 connections to provide isolation: two for mains in, two for HT out and two for LT out, but one end of the LT and one end of the HT secondary windings could be joined giving just 5 connections. Four connections suggests just mains in and LT out, with the mains being used directly to supply the HT.
julie_m is offline
Old 16th Oct 2019, 12:13 pm   #32
vampyretim
These are the photos of the amplifier the 6x4 is hooked up directly to the mains and for some reason the 6x4's keep dying.
I will be changing the plessey before anyone mentions it.
Many thanks.
ID:	192015   Click image for larger version
Old 16th Oct 2019, 12:58 pm   #33
ms660
ms660's Avatar
According to the rectifier's valve data Rs should be around 180 ohms minimum per anode so far as I can make out for 240 volt mains.
Lawrence.
ms660 is offline
Old 16th Oct 2019, 3:48 pm   #34
John10b
Looking at your pictures it looks like there is a wire bridging across the Mains terminal on the transformer, or inadvertently shorting, I could be completely wrong of course! A few more pictures would be useful.
John
John10b is offline
Old 10th Mar 2020, 8:57 am   #35
FIXITNOW
FIXITNOW's Avatar
Just had one off these come my way to sort. Thread here:-
https://www.vintage-radio.net/forum/...d.php?t=164635
FIXITNOW is offline
Old 10th Mar 2020, 10:15 am   #36
crackle
Originally Posted by vampyretim View Post
Hi all,
Thanks for the replies. I'm actually away for a week or so and don't have the thing to hand. From memory though the amplifier seemed untouched so I don't think that it ever had a dropper. When I said that it was taking out the 6x4's when I got the thing it had a milky 6x4 with a cracked base so I replaced with a nos one and the amp was working for 20 minutes or so as I was working on the mechanics and I happened to see a flash and the fuse was taken out in my lamp limiter. Looking at the valve it has completely disconnected an internal connection (I think cathode but can't quite remember) of one of the pins. A huge current has been drawn and I was suspecting it to be the power supply caps.
Many thanks.
Your lamp limiter appears to not be wired correctly as any short in the equipment connected to it SHOULD NOT cause the fuse to blow.
The first valve was obviously no good, the second valve may have had a fault in it.
Test the smoothing caps for electrical leakage.
With the EL84 valve removed there should be next to no current on the path from the rectifier cathode to the first smoothing capacitor. (once the caps are charged up)
To measure this connect your ammeter via a 10k resistor in series with the HT circuit before the rectifier. There will be a high initial current, (25mA) but if after 60 minutes there is still more than 1mA flowing, replace the capacitor with a new one.
Be careful as you are working with live mains.
Mike
crackle is offline
Old 10th Mar 2020, 10:38 am   #37
Station X
Station X's Avatar
[QUOTE=crackle;1224082]
Mike
If like my own lamp limiter, the OP's incorporates a switch to short-circuit the lamp, then it's possible the lamp limiter's fuse could blow under fault conditions.
There'll be two fuses in series. One in the lamp limiter's plug and one in the player's plug. Either or both could blow.
Graham. Forum Moderator
Station X is online now
