27th Jan 2018, 6:01 pm | #1 |
A stupid question -heaters in series
I have a stupid question whose answer I can't see.
I wanted to use half an ECC83 and only one of its two heaters. 12.6v at .15A in series, 6.3V .3A in parallel, for use in a 12v parallel heater chain. 1.CONSIDER RESISTANCE OF HEATERS: I needed the resistance to balance using one heater. So what is the resistance of the heater in one half of the valve 6.3V/0.3 = 21R But back-checking, 12.6/0.15= 84R If the two resistances are connected in series, then the two individual heaters' resistances should sum to the total. (84R) 2.CONSIDER WHAT I NEED FOR CIRCUIT: I have 0.15A traveling through a circuit which needs to drop 6.3V I therefore need a resistor of 6.3V/0.15 A = 42R (Which is also half of the 84R total heater resistance) My brain is tired. It's been a hard week for work, and my mind is stuck in press officer mode, not technical mode. I'm not seeing something very basic about the difference between the two. Could someone please explain the discrepancy between 1 & 2 above? What is the resistance of half a heater? Many thanks Croozer Last edited by Croozer; 27th Jan 2018 at 6:13 pm. Reason: Error in circuit topography |
27th Jan 2018, 6:10 pm | #2 |
Re: A stupid question -heaters in series
Mistake in context if circuit topography
27th Jan 2018, 6:12 pm | #3 | |||
Your sums are correct.
Cheers, GJ
http://www.ampregen.com |
27th Jan 2018, 6:12 pm | #4 |
ECC83 has its heater in two sections, you're right.
Each section is 6.3V 0.15A (or 42Ω). So if you put in parallel, you draw 0.15A + 0.15A = 0.3A, obviously all at 6.3V. Effective resistance is half 42Ω, or 21Ω, which is exactly what you get by considering 6.3V and 0.3A. But if you put in series, you have 6.3V + 6.3V = 12.6V. And the resistance is 42Ω + 42Ω = 84Ω (resistances in series add), which is exactly what you get by considering the 12.6V at 0.15A. If you're just using one section, then it'll behave like a 42Ω resistor. |
27th Jan 2018, 6:14 pm | #5 |
Mistaken blank post above
27th Jan 2018, 6:15 pm | #6 |
The valve has two heaters, one for each half. Each is rated at 6.3 volts 0.15A. They can be connected in series or parallel..
Why do you want to connect only one half of the heaters and then add a resistor?, why not just connect them as intended? |
27th Jan 2018, 6:32 pm | #7 |
All,
Many thanks for your quick response. I needed someone from the outside to point out a mistake so obvious I couldn't see it. I was intending to strap all unused electrodes together and thence to earth, in that context it didn't seem sensible to light the heater. But I don't know the correct procedure for using half a valve. Recommendations welcome |
27th Jan 2018, 6:38 pm | #8 |
I see no problem with running the heater on the unused half.
Unless others have better data info than I have I am not sure that which heater connection runs which half of the valve - if it is unspecified it may change for different makes of valve or different manufacturing plants. |
27th Jan 2018, 6:45 pm | #9 |
The only downside I can see for running the heater on the 'unused' half is that it introduces additional heat which - if the valve's being used in something like a VFO - could cause additional thermal drift. Using an external resistor located well away from any temperature-sensitive parts of the VFO reduces this problem.
[I'm currently trying to reduce the thermal-drift of the VFO in a Trio 9R-59 communications-receiver which uses an ECC85 double-triode but only one triode is actually needed. The non-centre-tapped heater takes 0.45A @6.3V - to reduce local heating I'm pondering replacing this with a 12AT7 and only powering one filament - 0.15A @6.3V - so reducing the heating effect and - hopefully - reducing drift too] |
27th Jan 2018, 8:46 pm | #10 |
Many thanks. I'll run both heaters.
28th Jan 2018, 9:10 am | #11 |
I thought leaving a heater running on a valve without HT applied was a big no no, resulting in a damaged cathode. It's also wateful. If your running one section only at 12.6v as you say you'd have to drop the other 6.3v across a resistor. Better to tap off 6.3v from your 12v supply using a potential divider or use a CCS or 7805 and red LED.
Here's some good info - http://www.valvewizard.co.uk/heater.html Heater filaments arn't linear like resistors and have a different resistance cold as compared to hot. Andy.
28th Jan 2018, 9:21 am | #12 |
Your maths are correct, but I can't see why you would only want to run half the valve.
If you are concerned about the unused half suffering cathode poisoning even though you are not using it, presumably so that the valve remains viable in use elsewhere, then wire that half as a diode and put a few volts on the anode so it ticks over. Even 5v or 10v will keep it going for negligible HT current. Then its only one high value resistor extra. |
28th Jan 2018, 11:32 am | #13 |
It is possible to light only one half of the ECC83 if you connect to pin 4 or 5 (depending on which half you want) and pin 9.
28th Jan 2018, 12:49 pm | #14 |
Why not connect both halves of the valve in parallel?
What is the application? |
28th Jan 2018, 1:04 pm | #15 |
Indeed - but is there data on which heater connection is for which half? There is no mention in my Mullard Maintenance Manual (price 10/6)
28th Jan 2018, 1:09 pm | #16 |
Easy enough to find out by experiment I'd have thought. Personally I'd just connect the heaters in series or parallel to suit the supply voltage.
28th Jan 2018, 1:19 pm | #17 |
It's easy, pins 1 to 4 is one half, pins 5 to 8 is the other half, pin 9 is the heater common:
Second page: www.r-type.org/pdfs/ecc83.pdf Lawrence. |
28th Jan 2018, 2:16 pm | #18 |
Heat the side you are using. Leave the other cathode cold, and ground the electrodes.
A hot cathode but no current means cathode interface layer. A warm cathode with current means cathode bombardment. A valve lasts longest when it is either off or on, not something in between. |
28th Jan 2018, 2:21 pm | #19 |
Many thanks for all the replies.
I've never used only half a valve before, and I don't know what best practice is; my thought was to use only what I needed (cathode poisoning etc. ) but the other valve in circuit has 12 V heater. Cathode poisoning isn't really an issue, because the other half of the valve is redundant, but as a 'good practice' measure, eg. in case I ever want more gain, the cost of a resistor in the heater circuit seemed a low price to pay. The application is af amplification in a pantry TX. |
28th Jan 2018, 2:47 pm | #20 |
You could always connect a 6.3 Volt 0.3 Amp lamp in series with the heater to drop from 12V to 6V and use this as a dial lamp or power indicator. I would personally just use the heaters in series as intended and risk damaging the other half of the twin triode. Is it of any great consequence?
Alan. |
