24th Jan 2018, 6:56 pm | #1 |
High current connectors
I am looking for suggestions for low voltage (12V) power connectors that will drop hardly any voltage at about 150A.
Anyone know a good solution (that is not entirely expensive)? |
24th Jan 2018, 7:19 pm | #2 |
Re: High current connectors
Anderson Powerpoles are used on electric vehicles and aren’t unusually expensive. Not sure about 150A though, you’d have to check. PP120 seems to fit the spec.
24th Jan 2018, 9:01 pm | #3 |
24th Jan 2018, 9:05 pm | #4 |
There are also Dinse connectors at welding suppliers.
25th Jan 2018, 4:50 am | #5 |
Hi Anderson power poles and similar types for FLT applications should do well. I believe they are rated up to 100V and a 200A unit will withstand 1000A for a minute or so.
They are normally crimp connectable onto 16/25/35/50 mm^2 cables, some have solder buckets. A nice scraping action and an arc tip on the higher current types. Ed |
25th Jan 2018, 12:20 pm | #6 |
I'd recommend the Anderson SB series - they're like Powerpoles, but have two contacts in one housing. They're very popular for charging fork lift trucks and the like, and I use them for battery connections up to 350A with no problem. They're intended to be crimped but if you have a suitably beefy soldering iron they solder easily because they're silver plated.
Chris
29th Jan 2018, 5:14 pm | #7 |
Thanks for that everyone. Some interesting suggestions.
I hadn't heard of some of those. I was worried that I would have a problem with this. |
29th Jan 2018, 6:11 pm | #8 |
Anderson connectors are great, those Durite ones from the auto electrics shops look just the same.
For the very biggest ones I use a blowtorch and solder them in. Lots of solder in the terminals and lots of flux on the cables, and in they go. The terminals come out of the shell first so no need to worry about melting it.
Kevin |
29th Jan 2018, 7:07 pm | #9 |
Anderson plugs are also used by many bus companies for jump starting where access to the batteries is limited.
They are very rugged devices. Cheers, John Joe. |
30th Jan 2018, 9:49 am | #10 |
They're also used on the ramp leads / power supply output connections on Siemens MRI magnets.......
