Old 3rd Sep 2020, 11:39 am   #1
stevehertz
stevehertz's Avatar
Default Bush VHF94 - too much drift on FM?
I've just finished a full restoration and realignment of a Bush VHF94 (same as 64). From switch on to fully warmed up it drifts about 560Kc on FM. That seems excessive. What should I expect for a set with no AFC? Anyone with the same set able to comment?
Before people say check this or that component, all potentially dodgy caps have been changed and all valves tested out of the set.
stevehertz is online now
Old 3rd Sep 2020, 11:48 am   #2
ms660
ms660's Avatar
Default Re: Bush VHF94 - too much drift on FM?
BBC Bush VHF64 tests here if it's any use:
https://www.bbc.co.uk/rd/publications/rdreport_1958_19
Lawrence.
ms660 is offline
Old 3rd Sep 2020, 1:19 pm   #3
Nickthedentist
Nickthedentist's Avatar
Mine has no noticeable drift at all.
Nickthedentist is offline
Old 3rd Sep 2020, 4:09 pm   #4
stevehertz
stevehertz's Avatar
Great document, thanks. Didn't know that the BBC did reports on commercial sets!
Old 3rd Sep 2020, 4:22 pm   #5
Nuvistor
Nuvistor's Avatar
Hi Steve,
Off topic but a list of BBC tech docs.
http://downloads.bbc.co.uk/rd/pubs/r...eport-list.pdf
Frank
Nuvistor is online now
Old 3rd Sep 2020, 4:41 pm   #6
Philips210
Thanks to Frank and Lawrence. I was unaware of such documents being available. A quick look through the listings and I see colour television trials in the early/mid 1960s. Also stereo radio broadcast tests as well. Very interesting stuff.
Regards
Symon
Philips210 is offline
Old 3rd Sep 2020, 5:00 pm   #7
Graham G3ZVT
Graham G3ZVT's Avatar
Don't discount the possibility that a brand new capacitor in the frequency changer area might increase the amount of drift, if its temperature coefficient is significantly different from the original.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 3rd Sep 2020, 5:20 pm   #8
Philips210
I think I be inclined to try another known good ECH81 valve. I have had problems with these in AM/FM sets with intermittent start up of the LO when the radio is switched to FM.
I wonder if the HT voltage to the frequency changer is drifting. If so could that account for oscillator drift?
Regards,
Symon
Old 3rd Sep 2020, 5:21 pm   #9
Freya
Freya's Avatar
I have had lazy ECH81s which gradually increase emission, creating the same effect.
Stephen
Freya is offline
Old 3rd Sep 2020, 5:24 pm   #10
PaulR
PaulR's Avatar
My VHF 61 drifts quite a bit despite changing every Hunts cap but my Cossor 524 is rock solid. I have another VHF 61 to restore, it will be interesting to see whether that drifts
Paul
PaulR is offline
Old 3rd Sep 2020, 5:33 pm   #11
Leon Crampin
Fit a blackened screening can to the ECC85. This will reduce drift to acceptable limits in most cases by limiting its temperature rise. Sometimes, selecting an appropriate ECC85 will help - the best one I have is, surprisingly, branded "Edicron".
The ECH81 will have no bearing on FM tuning drift as it functions as an IF amplifier on this band. AM performance of these sets is mediocre, to say the least.
Leon.
Leon Crampin is offline
Old 3rd Sep 2020, 5:34 pm   #12
stevehertz
stevehertz's Avatar
HT is pretty rock solid, I checked it over an hour period. Very minor (1v or so) changes that were probably attributable to mains fluctuations.
Old 3rd Sep 2020, 5:37 pm   #13
stevehertz
stevehertz's Avatar
Thanks Leon. I recall you have done a lot of work on these sets. I'll give that go.
Old 3rd Sep 2020, 8:12 pm   #14
FERNSEH
FERNSEH's Avatar
Nickthedentist wrote: "Mine has no noticeable drift at all."
The VHF64 I'm working is the same but other VHF Bush radios I have drift quite badly, the two VHF90 sets are the worst.
Leon Crampin wrote: "AM performance of these sets is mediocre, to say the least."
With two IF stages and the best frequency changer valve of all one would have expected much better performance.
The Bush VH80 is a much better performer.
DFWB.
FERNSEH is offline
Old 3rd Sep 2020, 8:19 pm   #15
unitelex
Smile Re: Bush VHF94 - too much drift on FM?
Ditto, I have a VHF61 I restored already, and another one waiting. I will also do the same drift comparison I might also try blackening the can on the ECC85.
Best Regards
Chris
unitelex is offline
Old 4th Sep 2020, 11:53 am   #16
stevehertz
stevehertz's Avatar
I've fitted a black screening can, no difference. Will see if I've got another ECC85 to try.
Old 4th Sep 2020, 1:45 pm   #17
PaulR
PaulR's Avatar
I am watching this thread with interest!
Paul
PaulR is offline
Old 5th Sep 2020, 8:23 am   #18
Tractionist
Ditto !
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 5th Sep 2020, 11:39 am   #19
stevehertz
stevehertz's Avatar
'No drift' messages heartening to hear. Would rather have a fault that needs to be located than a problem with no solution (the problem is, finding the fault!).
Old 5th Sep 2020, 12:42 pm   #20
PaulR
PaulR's Avatar
Maybe the "fault" is the combination of valves and components and their precise position in that particular radio. Just a thought.
Paul
PaulR is offline
