7th Mar 2019, 10:47 pm | #1 |
Hitachi VT-11E VCR not working
I recently bought a 1982 Hitachi VT-11E top-loader VCR, and it has some problems. When I insert a VHS and press play, rewind or fast forward I only hear the motor spinning. The tape isn't taken out of the cassette and wrapped around the video head, nothing happens. I also found a broken belt when looking in the VHS slot. It should have connected a small wheel to the supply pully. I used a rubber band of the same size as the old belt as a temporary repair, but nothing still happens. I haven't opened it though, I just put my fingers in the slot and very, very carefully did it. What can be the problem?
7th Mar 2019, 11:35 pm | #2 |
Re: Hitachi VT-11E VCR not working
I would either clean or replace the idler.It’s in the centre of the deck at the front.
Dave |
8th Mar 2019, 7:41 am | #3 |
Thank you, I'll try cleaning it and see if it works.
8th Mar 2019, 7:57 am | #4 |
Hi
Replace the rubber belt in loading motor. |
8th Mar 2019, 8:14 am | #5 |
Good morning.
I already cleaned the idler but it doesn't work. I'll try replacing it and also replacing the belt in the loading motor, and see if that works. |
8th Mar 2019, 3:07 pm | #6 |
You do need the correct loading belts which are a tight fit on the pulleys. The idler doesn't come into play till the capstan motor turns and the loading is completed.
8th Mar 2019, 3:33 pm | #7 |
And didn't the VT11 use two belts to perform lacing? Dried grease will be a problem now as well. Why they used two always puzzled me.
8th Mar 2019, 4:13 pm | #8 |
That's right - and they had different part numbers, though they looked identical.
8th Mar 2019, 4:20 pm | #9 |
Yes Glynn, you must have been in the trade around the same time as me. That model, apart from the loading belt was reliable. Gentle on heads as well, oh, apart from the idler.
8th Mar 2019, 5:45 pm | #10 |
Failure of the reel idler was a common fault on this range of VCRs. In your case, I would respectfully suggest that you replace this and also the loading belt. Cleaning the idler was never very successful.
8th Mar 2019, 8:28 pm | #11 |
Who will confess to turning the idler round? I did, a lot. Emery cloth never seemed to be enough, but spin it round. You were away.
9th Mar 2019, 12:10 am | #12 |
Been there done that on a friday night call on the way home
https://www.facebook.com/gntrading |
9th Mar 2019, 8:57 am | #13 |
Oh the memories, idler tyres turned over, indifferent loading belts and groaning capstan motors.
I also remember the look on a very-well spoken chaps face, who insisted his old VCR parts were returned to him. Not a problem, the repair turnaround was very quick too since we had a service kit in stock for his machine. The service kit was genuine Hitachi, the customers VCR? was a B&O! We casually pointed out the 'Made in Japan' and Hitachi logo on his Danish B&O VCR's, rear label. I also remember ordering a LOPT for one of 'their' tellies, we were stunned as an empty 40-foot B&O truck rolled up to the workshop door, parcel in the back. We could only surmise he'd completed his bulk deliveries beforehand, though the comic value amused us. Mark
Slowly turning the 'to-do', into 'ta-dah' |
11th Mar 2019, 11:57 pm | #14 |
Hi. Check the two loading belts at the bottom side of the mechanism.
Fivos |
12th Mar 2019, 5:19 pm | #15 |
I checked the loading belts and found out one is broken. Thank you all for helping me!
