Old 8th Nov 2018, 11:07 pm   #1
Jolly 7
Default Unidentified vintage components
These components were in a box of vintage resistors. I don't know what they are and where they were used. Can anyone identify these please.
Jolly 7 is online now   Reply With Quote
Old 8th Nov 2018, 11:13 pm   #2
60 oldjohn
Default Re: Unidentified vintage components
Insulated stand offs and feed through ? used before tag strips the bush TR82 uses plastic items very similar.
John.
60 oldjohn is online now   Reply With Quote
Old 8th Nov 2018, 11:17 pm   #3
emeritus
I have a couple of the bottom item, which is a feedthrough for bringing out a connection through a metal barrier or the wall of a metal box. It would be soldered in place. I don't recognise the other two.
emeritus is offline   Reply With Quote
Old 8th Nov 2018, 11:24 pm   #4
Andrew2
The top one is a simple stand-off tag connector - a single version of a tagstrip if you like. The spacer will be ceramic. The middle one looks very strange!
Andy G1HBE.
Andrew2 is offline   Reply With Quote
Old 8th Nov 2018, 11:24 pm   #5
Jolly 7
Thanks gentlemen. That does make sense. First I thought they were old diodes but they are showing continuity on my meter apart from the ceramic glass 'waist' area.
Old 8th Nov 2018, 11:55 pm   #6
m0cemdave
I also have some of these.
The lower item is probably made by KLG (of spark plug fame) and widely used in oil-filled transformers (Parmeko etc) where they are soldered into the sealed can to form the terminals.
The middle one is of similar application but made of glass.
m0cemdave is offline   Reply With Quote
Old 9th Nov 2018, 12:13 am   #7
Andrew B
Andrew B's Avatar
Feed through capacitors?
Concerned regarding the lack of migrating electrons.
Andrew now M0IIQ
Andrew B is offline   Reply With Quote
Old 9th Nov 2018, 12:48 am   #8
m0cemdave
These are designed for minimum capacitance. I have just measured a few of mine, and they are all around 4pF.
Old 9th Nov 2018, 4:29 am   #9
FrankB
Insulated feed thru's.
They also made feed thru capacitors that could look very close.
Come to think of it, an insulated feed thru would have a certain amount of capacitance.
FrankB is offline   Reply With Quote
Old 9th Nov 2018, 9:32 am   #10
ukcol
ukcol's Avatar
Agreed, except to add that it will be a feed-through capacitor, almost certainly of 1000pF (0.001uF).
Best Regards,
Colin McLaughlin
BVWS Member
ukcol is offline   Reply With Quote
Old 10th Nov 2018, 6:26 pm   #11
boxdoctor
boxdoctor's Avatar
I seem to recall that the feed-through capacitors have a silver, or silvery, covering over the outside outer surface of the ceramic tube.
If so, as ukcol says, almost certainly 1000 P.F.. Tony
The job "couldn't be done".
He didn't know that,
So he did it.
boxdoctor is offline   Reply With Quote
