Old 18th Oct 2018, 9:47 pm   #41
astro63
Default Re: Vidor Jamboree record player
You can adjust the motor governor weights theres a little screw on the shaft, undo a fraction hold the spindle part that would touch the idler wheel and very slightly a few mm turn the weight bit anti clockwise, tighten that little screw and try the speed, if to slow do the opposite turn couple of mm clockwise .
Avoid oil near the carbon brushes
astro63 is offline   Reply With Quote
Old 18th Oct 2018, 10:07 pm   #42
crackle
crackle's Avatar
I am wondering if it was too fast because the OP was running it from a 9 volt battery.
I wonder why it has a governor if it has a variable resistor to adjust the speed.
Mike
BVWS Member
The KB Museum
My collection in the Radio Museum
crackle is offline   Reply With Quote
Old 19th Oct 2018, 11:18 am   #43
robert.copley1
had a look at it again today and the speed control is now working OK perhaps the weights were stuck ! no great shakes from the volume though
robert.copley1 is offline   Reply With Quote
Old 19th Oct 2018, 10:48 pm   #44
astro63
shakes? sorry bob what do you mean?
Old 19th Oct 2018, 11:49 pm   #45
robert.copley1
volume John (not a lot) bob
Old 20th Oct 2018, 11:14 pm   #46
astro63
Have you tried a good output cartridge direct to the terminals where the pick-up wires are aka bypassing the fitted cartridge? It could be dead.
Old 21st Oct 2018, 8:46 am   #47
Originally Posted by robert.copley1 View Post
"no great shakes from" the volume though
Slang expression- maybe local or dated means "nothing special about".
Not some obscure technical term about sound levels
Old 21st Oct 2018, 4:25 pm   #48
robert.copley1
John the original cartridge was dead , now I've fitted one of those modern cartridges, the sterio type with the 4 v shaped tags, the volume is about a third it should be , but I'm not bothered too much as I just really wanted to get it working sorry about the slang (shakes) can't remember where I picked it up though bob
Old 21st Oct 2018, 9:22 pm   #49
astro63
i see, modern less output well if it does bother ya i can take the set of ya hands ;-) haha glad you got it going
Old 21st Oct 2018, 10:08 pm   #50
robert.copley1
if I find another it's yours bob
