Old 18th Aug 2018, 11:35 am   #1
retroaudio
Default KB Transistor super 8
I recently purchased one of these. The seller was running it from a 9 volt AC wall wart !!!!!!!!!. The original 4 pin battery plug had been cut off and I was left with three wires. I am going to run this off a PP9 battery however I was unsure if there is a right way and a wrong way to do it. The original battery would have been a pp11 which i believe is 2x 4.5 volt batteries in one box with two seperate positives and a single negative ?
regards Alex
retroaudio is offline
Old 18th Aug 2018, 1:36 pm   #2
crackle
Default Re: KB Transistor super 8
Yes it is possible to run the KB VP21 Rhapsody Super 8 from a single 9v PP9.
The original PP11 battery was two separate 4.5volt batteries but they were connected in series at the 4 pin plug, the resulting centre tap went to the speaker. So in effect what you had was +4.5 0v -4.5v.
You can ignore the centre tap wire (it was orange in my radio) and just connect the battery +ve and -ve terminals direct to the on off switch.
You do not need the 0 volt connection, the two 200uf capacitors form the return path for the speaker that is needed for the amp to work.
I have previously been advised that you should ensure that the two 200uF electrolytic caps C23 & C24 are both in good condition.
See photo.
If the detail is too small in the photo in this thread then use this link below to link to a larger photo on my website.
http://www.kbmuseum.org.uk/kb_images...b-vp21-pp9.JPG
Mike
crackle is offline
Old 24th Aug 2018, 9:22 pm   #3
crackle
I wonder if the OP actually came back to see the reply I left to help him.
Mike
crackle is offline
Old 24th Aug 2018, 10:45 pm   #4
jonnybear
jonnybear's Avatar
Yes it is nice to get some sort of feedback when you have taken the time to reply to queries.
John
jonnybear is offline
