7th Aug 2018, 11:24 pm | #1 |
Tandberg 9000X only recording one side.
I have a Tandberg 9000X. I've never heard it play until now, as it had logic problems when I bought it and so, until today, I've never had it working.
It plays tape fine, both channels are playing back as they should and it sounds fantastic. It inputs fine as in both left and right channels have input audio. However, with the rec switches pressed in, both the VU`s light up, but only one needle is moving, and when playing back the recorded audio, only one channel has been recorded. Can someone advise me on a course of action to take. I have re-capped the main board, and I have been over and over it and all caps are correct and orientated correctly. Many thanks for all help. |
7th Aug 2018, 11:42 pm | #2 |
Re: Tandberg 9000x only recording one side.
With the deck in "record", a good signal input to Line In of each channel and a stereo amplifier connected to the Line Outs, do you get a signal in both channels of the amplifier?
In the unlikely event of this being a three-head machine, you should have the monitoring switch set to "Source" for this test.
7th Aug 2018, 11:52 pm | #3 |
Hi Julie , it is a half track , 3 head machine . Yes I have good source signal with the machine in rec , with the monitoring set to source . However only one VU is showing signal there is stereo sound from the unit though .
8th Aug 2018, 12:09 am | #4 |
If you've got a few metres of sacrificial tape with programme on both channels, try recording a stereo source over it with the monitoring switch set to "Tape". What is coming out of the offending channel during recording? Silence means you have a good erase but the signal is getting lost -- we've already proved that it must be somewhere downstream of the monitor switch. The original sound means no erase -- so most probably, that channel is not even being armed for recording. That suggests a switch or relay fault.
Have you got a circuit diagram?
8th Aug 2018, 12:14 am | #5 |
im getting silence on the dead track so its the signal thats getting lost somewhere.
Yes I have the schematic . |
8th Aug 2018, 12:28 am | #6 |
We know the signal is getting at least as far as the monitor switch, but not as far as the level meters. So that narrows it down to a few likely components. And we have a known-good copy of the same circuit. Start by comparing DC voltages on corresponding transistor / IC pins between the two channels. If necessary, you can probe for audio signals using your amplifier input, with a 0.1μF capacitor in series.
8th Aug 2018, 12:39 am | #7 |
OK thanks I will go have a poke around with the scope and see if I can narrow it down , thanks for your help . I`ll put a 10k sine into it in parallel and see if I can figure out where it disappears. I`m bound to get stuck but I`ll give it my best shot ..haha
8th Aug 2018, 12:56 am | #8 |
OK, I`ve just checked UA101 , pin 1 should have 13v , it has 25v , the corrresponding pin (13) for the right channel does have the correct voltage .
8th Aug 2018, 1:23 am | #9 |
OK so probing with the scope shows nothing coming out of pin 1 (L) of the op amp , there is a signal coming out of pin 13(R). So the signal either isn`t making is as far as the op amp or the op amp is the problem on the left side. I`ll carry this on tomorrow , I`m sweating like a pig in this heat time to call it a night I think .
8th Aug 2018, 1:27 am | #10 |
If there is a resistor from that pin to ground, it could have gone high-value. Otherwise, if the only thing pulling it low is the IC, that could well be faulty.
8th Aug 2018, 1:33 am | #11 |
There`s a resistor there but it seems ok .
8th Aug 2018, 1:35 am | #12 |
I have the 13v at pin 5 and the 23v at pin 3 , but i also have 23v at pin 1.
8th Aug 2018, 4:56 am | #13 |
What voltage do you measure on pin 6 of that IC?
8th Aug 2018, 9:04 am | #14 |
Could be a short or leaky capacitor in the feedback circuit. eg C112, C115, C116, C118
Do you get the same problem on all tape speeds? That would eliminate C116 and C118 if you get the same problem at all tape speeds. |
8th Aug 2018, 9:15 am | #15 |
Hi ,
yes same problem at all tape speeds , but i believe the input and output voltage should be the same , so im pretty sure now the op amp is borked , i have recapped all the electrolytic caps with panasonics |
8th Aug 2018, 11:20 am | #16 |
8th Aug 2018, 12:38 pm | #17 |
I`m beginning to think you may be correct . I`ll report back once i`ve replace them all with film .
8th Aug 2018, 12:52 pm | #18 |
FIXED : it has those stupid stand up resistors and 2 were touching . Don`t you just hate those stupid things . They were hard to see too , poxy things .
8th Aug 2018, 4:06 pm | #19 | |
If the IC really is an op-amp (and I have not check the data sheet to be sure) then unless the 2 inputs have essentially the same voltage the output will hit one of the supply rails. Moreover, looking at the circuit you posted, there is a DC path, through resistors, from the output to pin 6. Everything else is connected to that via capacitors. So if you get a different DC voltage at pin 6 to that on the output then either The IC is faulty and drawing a significant current through its input pin One of those capacitors is leaky There is another short somewhere (as you found) |
8th Aug 2018, 5:14 pm | #20 |
Thanks for that Tony. I like that you have explained that . Brain food is always good . Thank you .
