27th Jan 2016, 1:28 am | #1 |
The wood effect mystery
Just bought a mid-fifties Sobell set in plastic, but with a very convincing wood effect. Not the sort of thing you could patch up, but I was wondering how this was created? I have had GEC sets like this and it looks good quite close up.
Knobs and tubes rule ok |
27th Jan 2016, 2:06 am | #2 |
Re: The wood effect mystery
Hot stamping was used on TV cabinets so far as I know.
Lawrence. |
27th Jan 2016, 2:19 pm | #3 |
If it is textured surface it may well be as Lawrence suggests hot-stamped but in the 1950s photographic copies of woodgrain on paper were increasingly being developed as inexpensive encapsulated wood-effect trim applied to carcasses - the forerunner of Fablon (and todays foil-laminates), some of which were (unconvincingly) textured and seemingly not an applied material.
27th Jan 2016, 3:37 pm | #4 |
When the cabinet is really badly gone and it's worth starting again from scratch, you can build up a new wood effect by using a fan-shaped brush to apply lines or squiggles of walnut toner over a sprayed-on gold base. Then finally, a light sealing coat of clear acrylic.
Not a fun job. I've only ever had to do it once, on this GEC. Steve
https://www.radiocraft.co.uk |
28th Jan 2016, 12:11 am | #5 |
I always wondered how they did it on those post war GECs, every one I've seen has been part-worn off. I'm guessing it's screen printed (?); it's a smooth surface. Pre war models of the same shape were luxuriously veneered!
I have a grundig radio with worn-off woodgrain image. There seems to be a plethora of wood graining brushes, combs, draggers, grainers, and other gadgets for this purpose. That GEC looks good Steve and I've used your website for cabinet finishing tips many a time!
Kevin |
