27th Sep 2014, 4:42 pm | #1 |
Moving Iron Meter Calibration
Is it likely that a moving iron voltmeter (0 - 250v), intended for use at 400Hz, will measure accurately at higher frequencies, up to 1600Hz?
I'm not sure what affects the calibration of a moving iron meter! Many thanks, Andy |
27th Sep 2014, 8:03 pm | #2 |
Re: Moving Iron Meter Calibration
Thickness of any laminations..... impedance of coil.....
I would expect it to read low if anything. Sounds like time for a trial with a sig gen and 'scope to see what happens.
27th Sep 2014, 8:09 pm | #3 |
They're definitely frequency-sensitive. And profoundly waveform-purity-sensitive too: you don't want to trust them to read accurately if fed from a "modified-sinewave" power-inverter/UPS or if wired across a circuit where the power-factor is significantly off from unity.
28th Sep 2014, 9:40 am | #4 |
Thanks for the replies..................even if they don't give the answer I was hoping for!
I shall have to think again. Andy |
