10th May 2020, 6:51 pm | #321 | |
Re: Commodore PET 3016
10th May 2020, 7:01 pm | #322 |
I've replied further to your oscilloscope questions in the other thread, you are more likely to get opinions about it over there I think. We'll keep this one for the PET itself.
11th May 2020, 9:20 pm | #323 |
Hi- I contacted someone on a PET/CBM Facebook group and went through a few checks. For example, I plugged the tape deck into the PET and pressed play. I then switched it on. What should have happened is that the tape deck should have switched on for about a second and then it should have stopped. It didn’t, it carried on running which means there is a problem on the main board not the monitor apparently.
11th May 2020, 9:52 pm | #324 |
That is entirely possible.
In order for the monitor to work, the main PCB needs to be producing horizontal sync pulses. That's what we are aiming to find out, whether it is or not, in part so that you don't have to go chasing after a nonexistent fault in the monitor. If there are no horizontal sync pulses, then the problem is on the main board. Either way, your scope will come in useful not just for this job but for a whole host of other jobs. Next to a meter, it is the most useful piece of test gear you could ever have. |
11th May 2020, 10:21 pm | #325 | |
1st Oct 2020, 9:46 pm | #326 |
IC problem solved. Needed a new one to generate the video signal. Never did get to use my new oscilloscope!
1st Oct 2020, 10:55 pm | #327 |
Oh, you will.
Welcome back, John, I was wondering if something might have happened to you. Glad you seem to have solved your latest computer problem. |
9th Oct 2020, 4:36 pm | #328 | |
I am now online with the PET too using a WiFi Modem and a TTL Connector so am happily visiting a few BBSs! I can’t thank you guys enough for all your help! Cheers! John |
9th Oct 2020, 4:41 pm | #329 |
Did you ever get those replacement ICs for the IEEE interface, were they OK?
22nd Oct 2020, 10:28 pm | #330 |
22nd Oct 2020, 11:04 pm | #331 |
That is excellent - nice to see old machines fully restored.
23rd Oct 2020, 8:49 pm | #332 |
It’s working perfectly-touch wood!
