7th Aug 2019, 9:36 am | #21 | |
Re: First Television to use ICs
The earliest TV's I remember using an IC was probably the early RBM A823, from 1969, which used IC's for the 6Mhz sound intercarrier sound and one in the decoder.
Simon BVWS member |
7th Aug 2019, 9:46 am | #22 |
I suppose that it depends on the definition of "IC"- but if it's the accustomed idea of a small planar silicon beastie with lots of transistors in a compact package, then perhaps the ease of achieving consistent performance at TV IF and similar frequencies was an appealing USP, also making it easier for complex multi-stage broadband near-DC to 6MHz or so circuitry for video processing.
The TAA550-type devices are temperature-compensated and would be far better in this respect than lousy higher-voltage Zeners- I've wondered about using them as HT supply error amp references in place of the neons often found. |
7th Aug 2019, 10:17 am | #23 | |
From the Radiomuseum. https://www.radiomuseum.org/tubes/tube_taa550.html DFWB. |
7th Aug 2019, 10:18 am | #24 | |
Frank |
7th Aug 2019, 10:25 am | #25 |
From the Silicon Engine website: 1960 First Planar Integrated Circuit is Fabricated
https://www.computerhistory.org/sili...is-fabricated/ DFWB. |
7th Aug 2019, 11:11 am | #26 | |
7th Aug 2019, 11:39 am | #27 | |
7th Aug 2019, 11:45 am | #28 |
Yes, it was called an IC when I was in the trade, transistors etc inside:
https://datasheetspdf.com/pdf-file/769628/ETC/TAA550/1 From the SGS/ATES 1975/76 data book. Lawrence. Last edited by ms660; 7th Aug 2019 at 11:50 am. |
7th Aug 2019, 5:49 pm | #29 |
Yes G6Tanuki, sorry re spelling, felt a bit of a fraud mentioning the 33v clamping chip. But the post asked the first sets to use chips. I still think it may have been a zener inside but circuit references said it was an ic. I know that was the usual cause for tuner drift. Invariably it was the main ht line that was fed to it via a high value resistor of course. I always kept them in stock. Decca Bradfords that used a varicap tuner seemed to eat them. Yet the Pye 697 seemed more forgiving. I'm still in the trade and frequency synthesis has certainly come a long way. Luckily tuner faults are rare now. In fact you need a Leister gun nowadays as the tuner is hard mounted to the signal board. And they stopped using PC86\88 valves a while ago as well. Happy days.
7th Aug 2019, 7:05 pm | #30 | |
You were never entirely sure that the varicap tuner wasn't to blame, so the old TAA550 went back in your spares kit marked ?may be OK? Or maybe it was just me who did that.
-- Graham. G3ZVT |
7th Aug 2019, 8:52 pm | #31 |
The TAA550 didn’t give me a lot of trouble, the 33k feed going O/C I found failed more than the IC, still replaced a few but not a big problem.
Just shows how different makes and batches of TV’s could develop different faults.
Frank |
7th Aug 2019, 9:22 pm | #32 |
The integrated circuits TAA550 and ZTK33 exploit the temperature co-efficients of Zener diodes above and below 5.6volts.
From Google: "Above 5.6 volts, the avalanche effect becomes predominant and exhibits a positive temperature coefficient. In a 5.6 V diode, the two effects occur together, and their temperature coefficients nearly cancel each other out, thus the 5.6 V diode is useful in temperature-critical applications." From Wikipedia: https://en.wikipedia.org/wiki/Zener_effect As for the Rank-Bush-Murphy A823 wasn't the two chip decoder introduced in 1971? The already established SL901 and the SL917. These chips were never used by any other manufacturer. DFWB. |
7th Aug 2019, 9:47 pm | #33 | |
Picture, sound?, DOOR. |
7th Aug 2019, 11:06 pm | #34 | |
Cheers, |
8th Aug 2019, 2:48 am | #35 | |
9th Aug 2019, 1:36 pm | #36 |
As has been said, the TAA550 was a temperature compensated IC designed to cancel out the temperature coefficient of the varicap diodes.
The first varicap tuners I encountered in 1969 preceded the TAA550 so the compensation was arranged by a string of zeners with voltages above and below the 5.6 volt temperature coefficient threshold - three 6.8V in series with two 3.3 volt types |
9th Aug 2019, 3:38 pm | #37 |
Late production Plessey SL901. According to the date code this one was made in 1979.
DFWB. |
9th Aug 2019, 3:41 pm | #38 |
Were there circuit differences between the first SL901 and the B version, something in the back of my mind?
Frank |
9th Aug 2019, 4:53 pm | #39 | |
9th Aug 2019, 5:08 pm | #40 | |
I was hoping to find the early version of the SL901, the one with the heatsink attached to it. Some decoder boards were pierced to accept either IC. Was the original SL901 designated as SL901A? DFWB |
