4th Aug 2019, 5:10 pm | #1 |
Thermistor in heatshrink on power adaptor ?
Recently I've been dismantling an old 240V to 12V external SMPS power adaptor for parts. There seems to be a thermistor of some sort that's completely covered in heatshrink tubing. What purpose does the thermistor serve and why wrap it in heatshrink ?
4th Aug 2019, 5:19 pm | #2 |
Re: Thermistor in heatshrink on power adaptor ?
Possibly to limit the mains inrush current. When you connect an SMPSU to the mains you charge a capacitor from the rectified mains which can take a considerable current initially. The thermistor, in series with the mains to the rectifier starts off at high resistance (limiting the current), then the resistance drops as it warms up (due to the current flowing through it) and it has little further effect on the circuit.
4th Aug 2019, 7:16 pm | #3 |
Almost certainly inrush-current limiting, as Tony says. It's a cheap and cheerful approach, and works well. It has its limitations, if the unit is switched off and on again a few seconds later, the reservoir capacitor may be discharged but the thermistor still hot and low-resistance, so the switch-on surge will be large.
5th Aug 2019, 12:49 am | #4 |
And in heatshrink so when it explodes it doesn't spread shrapnel everywhere, supposedly.
5th Aug 2019, 1:11 am | #5 |
Thanks for the replies explaining how a thermistor works and it's disadvantages. Terry, thanks for explaining why a heatshrink tube should be used. Here's what I found elsewhere too:
"Take precautions with these inrush current limiters, especially if you're experimenting. They explode suddenly like firecrackers throwing pieces around, and let out a terrible stink and smoke..." Scary stuff ! |
5th Aug 2019, 5:09 am | #6 |
Yes, the stink is not nice but not as bad as Selenium rectifiers.
