30th Mar 2008, 6:28 pm | #1 |
Help with circuit needed - thanks
http://homepage.ntlworld.com/richard.../MISC/TRF.html
I'm unsure about the wiring circuit that I have copied from a 1920's homebrew RX I have. The circuit is copied as per the rx, but never-the-less I think the circuit connections are suspect. Can anyone help me sort the wiring/circuit out. Thanks. |
30th Mar 2008, 7:53 pm | #2 |
Re: Help with circuit needed - thanks
Hi, hope I can help, point 3 on the transformer would be connected to a grid bias battery (-ve) as to the others, well there's many variations, maybe if you could get hold of a few trf circuits, you'd have a better idea.
30th Mar 2008, 10:19 pm | #3 |
There seem to be a few things not right.
1. The V2 grid resistor goes to HT- according to your layout. 2. HT2 will need decoupling with a 1uF or so - originally it would have gone to a seperate 'tap' on the HT battery. 3. It's missing a capacitor to couple the anode of V1 to the grid of V2 (leaky grid detector). 4. As Alf says, the point 3 needs to go to a grid bias battery. 5. 1ohm is in fact 1M Otherwise I think it looks OK... |
31st Mar 2008, 12:21 am | #4 |
Okay. Point 3 needs either to go to "ground" or to a bias battery. Fine.
The problem seems to center arround the components just above V2. There are two resistors on one plasic component made by "Dubilier". Now I assume there are 2 capacitors in this unit. I think the anode load of V1 is a simple resistor. One capacitor in that Dubilier package must be the decoupling capacitor for that V1 load resistor. True? Now, where is the grid leak in this set. Is it in the grid of V1 or grid of V2? Is it not in V1 - and V2 is just an AF signal amplifier for the output valve V3? The other capacitor in that Dubilier unit (if there is one) needs to be the coupling capacitor between V1 anode and V2 grid. And what of the other resistor? Is that suppossed to be a terminating load for that coupling capacitor and a means of biasing v2 grid? Should that resistor then, connected to V2 grid - go to ground? Rich |
31st Mar 2008, 12:24 am | #5 |
To be honest I don't understand that item above V2. It looks like that Dubilier unit is two capacitors, each with a resistor across it.
31st Mar 2008, 10:57 am | #6 |
V1 is a regenerative RF amp.
V2 is a leaky grid detector. V3 is the audio amplifier. A leaky grid detector has capacitor coupled to the RF amp and a high value resistance to earth. During positive excursions the grid rectifies the AC signal causing the grid to move -ve to form the audio signal. It won't work if you connect it to a grid bias bettery. It's a sealed coupling unit? Afraid I don't know much about these and I suspect the content was a 'trade' secret...It should have the connections marked on the unit. Might be an inductor for the anode load, a coupling capacitor and the grid resistor. |
31st Mar 2008, 2:48 pm | #7 |
Okay, after further inspection that unit above V2 is made by LISSEN, not DUBILIER.
That could mean therefore that it's just a holder for two resistors. The bottom is filled in with pitch, but that does not neccssarily mean there are capacitors inside it. Now, as you see there are four terminals in that unit above V2. Top left is marked P. Top right LT. Bottom left H.T. and Bottom righ G. As you see these terminals do go to correct destinations. So that unit is probably just a holder for two resistors. I think. |
31st Mar 2008, 3:14 pm | #8 |
I bet that in that unit above V2 there is a capacitor connecting P. with G. This would represent the coupling capacitor from the anode of V1 to the grid of V2.
Can anyone please confirm that these LISSEN parts had a capacitor in them connecting P. to G? Thanks. |
31st Mar 2008, 6:50 pm | #9 |
Looks like it's all OK then. Before you try it out you will need to check for leakage current in the capacitors. Don't forget to add decoupling for HT2. You'll need high impedance headphones/speaker or an output transformer. The 215P spec is here http://www.andycowley.com/valves/old...ossor-p057.pdf and you need around -7.5V on the grid, 2V for the LT and around 120V for HT1.
That design should do a great job of blocking reception on your other radios too..Peter |
