Old 22nd Jul 2018, 8:11 pm   #1
Wishiknewmore
Default What is it? another car boot buy....
Hello
Just bought the attached volt/ammeter at a French car boot.
Can anybody add any information?
Many thanks in advance.
Philip
ID:	166403   Click image for larger version
ID:	166404   Click image for larger version
ID:	166405   Click image for larger version
ID:	166406   Click image for larger version
Wishiknewmore is offline
Old 22nd Jul 2018, 9:51 pm   #2
The Philpott
The Philpott's Avatar
Default Re: What is it? another car boot buy....
Wow. All i can do is hazard a guess at late '20's- (very) early '30's....although French gear of this era can look older than it actually is- they held onto certain styles longer than one might expect.
The Philpott is offline
Old 22nd Jul 2018, 10:20 pm   #3
kevinaston1
Possibly Joules Carpentier 1851 - 1921
Kevin
kevinaston1 is offline
Old 22nd Jul 2018, 10:36 pm   #4
Techman
Techman's Avatar
At a first glance it looks like an early high voltage and high current multi range meter. The multipliers for the voltage ranges being within the cage above the three inputs. The shunts for the amp ranges are taken up by the rest of the area and look to be particularly high current devices. The strange thing is that the meters have a bit of a 'ballistic galvo' look about them, so it could even be a piece of scientific lab gear, which may mean it's not quite as old as it looks, but still 50s to 60s.
Techman is offline
Old 23rd Jul 2018, 12:38 am   #5
The cramped at one end scale on at least one of the meters suggests moving iron movements. Could be AC (mains) meters. The shunts look like they could handle serious currents!
Herald1360 is offline
Old 23rd Jul 2018, 12:34 pm   #6
David Simpson
Lovely old wooden case, lovely old brass work, lovely old MI meters. Should clean up a dream. Well worth keeping as a display item.
Regards, David
David Simpson is offline
Old 23rd Jul 2018, 8:55 pm   #7
Ed_Dinning
Hi Philip, if you bring it over I can probably check its operation for you.
Ed
Ed_Dinning is offline
