Old 30th Jun 2020, 12:01 pm   #1
Peter73
Default Beethoven 4 valve set, Identified as a model 99.
Does anyone have any info' on this radio, I have drawn a blank so far.
The valve lineup is: PENA4, VP4B, 345V and an unidentified four pin rectifier.
I'm guessing that it dates from the late 1920's
ID:	209881   Click image for larger version
ID:	209882   Click image for larger version
ID:	209883   Click image for larger version
ID:	209884   Click image for larger version
Peter73 is online now   Reply With Quote
Old 30th Jun 2020, 12:04 pm   #2
Default Re: Beethoven 4 valve set
Beethoven radios often had a model/serial number stamped on the rear of the chassis where the aerial sockets are.
Keep the soldering iron hot.
Old 30th Jun 2020, 12:49 pm   #3
Peter73
Unfortunately there is nothing stamped on the chassis anywhere.
There is evidence of an ID plate having been removed just below a Mullard copyright plate on the inside of the cabinet.
Old 30th Jun 2020, 12:55 pm   #4
Interesting frame aerial.
I assume this is a mains powered TRF set?
Old 30th Jun 2020, 12:59 pm   #5
Peter73
Yes it would appear to be.
Old 30th Jun 2020, 3:08 pm   #6
PJL
That sort of dial would place it around 1933/34.
PJL is online now   Reply With Quote
Old 30th Jun 2020, 4:36 pm   #7
Yes, not likely to be earlier than about 1933. Droitwich opened in 1934, but the frequency would have been announced in advance and manufacturers would have labelled their dials accordingly.
At some time Beethoven switched from TRF to superhets. My own model 64 is a TRF and I believe "Radio Radio" shows a slightly later numbered model which was a superhet. The model shown would probably have had a lower model number than that.
EDIT. I just had a look at the circuit for model 77 which is a mains superhet.
Old 30th Jun 2020, 4:57 pm   #8
Gridiron
Only similar sets listed in the Mullard Valve Replacement guide are:
AC78 : VP4 or VP4A (7 pin), 354V, PENA4, IW3
AC99 : VP4 (7 pin), 354V, PENA4, IW4/350
283 : AC/VP1, 354V, PENA4 (7 pin), IW4/350
If model 77 is the same as AC77 this is must be a superhet as has a FC4 in the list of valves.
Mike.
Gridiron is online now   Reply With Quote
Old 30th Jun 2020, 5:25 pm   #9
Mike.
Radio Museum have a picture of a 77, but none of an AC77. I don't know whether they're the same set.
Old 1st Jul 2020, 10:42 am   #10
Peter73
Thanks for your input gentlemen, I will keep looking.
Old Yesterday, 2:55 pm   #11
Peter73
Apologies gents, I should have gone to Specsavers ! How I missed the numbers on the Gram socket panel I really don't know.
99/4333 does this help?
Old Yesterday, 3:01 pm   #12
Beethoven model 99 serial No. 4333.
That probably doesn't get you any further than a positive ID though.
Old Yesterday, 4:08 pm   #13
Something odd to me about this receiver, cabinet front doesn't look right, another receiver planted in the cabinet? Different chassis but similar tuning scale and loudspeaker bars in this one:
https://www.radiomuseum.org/r/beetho...per_minor.html
ms660 is online now   Reply With Quote
Old Yesterday, 5:37 pm   #14
PJL
Here is another one: https://www.the-saleroom.com/en-gb/a...8-abeb0126de64
Old Yesterday, 5:45 pm   #15
That's my theory out the window then.
Old Yesterday, 5:45 pm   #16
Looks like the mains transformer in the OP's set is a replacement.
Old Yesterday, 7:16 pm   #17
PJL
Your theory could be close, maybe Beethoven ordered a load of cabinets and the chassis didn't fit so they reworked by slapping an outer panel on the front.
Old Today, 2:14 pm   #18
Peter73
Default Re: Beethoven 4 valve set, Identified as a model 99.
Thanks very much PJL for identifying my set, much appreciated.
Pete.
