Old 30th Jun 2005, 5:52 pm   #1
oldeurope
oldeurope's Avatar
Thumbs up easy 100% modulation adjustment (sound)
http://www.your-normwandler-page.de.vu/
Good evening,
In my 405 modulator the sound input has a poti to adjust the
modulation depth.
To make the agliment easy I made a 100% modulation detector for the
sound modulation depth adjustment.
It is a red LED that flashes when you have overmodulation.
So adjust the poti that the LED just not flashes to get 100% sound
modulation.
You only need two resistors a transistor and a LED.
I build this very helpfull circuit in the MK III converter/modulator
and in the London Birmingham modulator.
Pics will follow soon, and I will update the converter/modulator thrads
step by step.
Kind regards
Darius
Name:	Übermodulationsdetektor Ton Forum.png
oldeurope is offline
Old 25th Aug 2006, 8:06 pm   #2
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Re: easy 100% modulation adjustment (sound)
Moved from archive to main section as requested by Darius
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 30th Aug 2006, 4:38 pm   #3
oldeurope
oldeurope's Avatar
Thumbs up Re: easy 100% modulation adjustment (sound)
Thanks for making it possible to update it.
An additional resistor from base to ground makes it possible to detect a lower modulation depth.
Here you can see a modulator using this stage:
https://www.vintage-radio.net/forum/...ad.php?t=10790
It is possible to drive an automatic level control ALC with this stage.
I drawed the ALC stage alone for an easier understanding.
Kind regards,
Darius
Name:	modulator schematic sound ALC.png
